Electrical Connector in the back
/ Electrical Connector in the back #1
heitjer
Houston, TX
LS R4041 & LL4100 FEL
Guys,
my LS4041 has an electrical connector behind the seat. I assume this is for trailer lights and possible breaks. Can someone point me to the name of that connector and does anyone has a pin-out?
I like to see if it is possible to power a small electrical pump for a sprayer from this outlet.
regards
heitjer
/ Electrical Connector in the back #2
heitjer,
Looking at the schematic that I have for my R3039, I do not think the Trailer plug has 12+ in it. I do see a connector listed as an 'Auto Leveler Power Source' that is 2 pins, possibly near the rear someplace, that has 12+ and ground. I am not sure if this is keyed, although I suspect it is, since it is sharing the PTO fuse.
Hope this helps...
Mike
/ Electrical Connector in the back #3
Guys,
regards
heitjer
I don't know anything about the LS tractors, but I'd guess you're right. My Kubotas had such a plug, under the seat, and I used it to power a Shurflo pump on a 50 gallon spray rig.
/ Electrical Connector in the back #4
is that the 7 pole connector on the back? this is the diagram for my xr4046hc which i would think will be the same. Hope it works for you. just use a 12 volt test light to confirm. 20140317_085141.jpg
/ Electrical Connector in the back #5
This is probably a stupid question but what type of male plug insert does that take? Is this a typical 7 pin type trailer plug or is it some kind of European type of plug? I have wondered this for sometime but it has never came up, and I didn't need it yet but is seems pertinent.
/ Electrical Connector in the back #6
they show in the book two versions, , the European one and the ASAE one. The Asae one I believe is American SAE.
The Plug is the same one that is used on semi tractors for their trailer plug in. I tried it, but all my stuff that I would pull is the flat pin rv style so I replaced it with an rv receptacle. the issue that I had was after removing and replacing the round pin to the flat pin receptacle, I found the little plug in behind it to tie it into the loom and the wires are extremely light gauge. I am going to run an additional wire from the battery back to the plug with some #12 gauge wire and a new fuse so that I won't get a meltdown if I want to run a pump or anything that has a heavy power draw yet I still want to be able to just plug it in. this way I will be able to power different items without worrying.
/ Electrical Connector in the back #7
This is a 7 "pin" European plug, not to be confused with a 7 "flat" RV plug. I use a utility trailer to haul hay and picked up a conversion plug to go from 7 round to 4 flat at TSC. I made a jumper to go from the trailer light plug to the adapter. All my trailer lights and signals work.
/ Electrical Connector in the back #8
Duh... I forgot the manual had that image!
/ Electrical Connector in the back #9
Are you sure it is European or just a round 7 pin like you get on most trucks now a days with a trailer tow package?
/ Electrical Connector in the back #10
The last time I was in a U-Haul place, I noticed they have a lot of the conversion plugs.
/ Electrical Connector in the back #11
its a 7 pole , round plug , same as on my big truck.
you can get them at most truck stops , parts houses etc.
/ Electrical Connector in the back #12
That is what I was looking for. I guess I could have just looked but it is just so dammed cold out still. It was 27 this morning still I am soooooo tired of winter, not supposed to get over 35 on Thursday that is the first day of spring. I think someone up there forgot to turn the page on the calendar!
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
Danuser 3Pt Post Driver (A66408)
Danuser 3Pt Post...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
