Electrical Connector in the back
/ Electrical Connector in the back #1
heitjer
Bronze Member
Houston, TX
LS R4041 & LL4100 FEL
Guys,
my LS4041 has an electrical connector behind the seat. I assume this is for trailer lights and possible breaks. Can someone point me to the name of that connector and does anyone has a pin-out?
I like to see if it is possible to power a small electrical pump for a sprayer from this outlet.
regards
heitjer
/ Electrical Connector in the back #2
heitjer,
Looking at the schematic that I have for my R3039, I do not think the Trailer plug has 12+ in it. I do see a connector listed as an 'Auto Leveler Power Source' that is 2 pins, possibly near the rear someplace, that has 12+ and ground. I am not sure if this is keyed, although I suspect it is, since it is sharing the PTO fuse.
Hope this helps...
Mike
/ Electrical Connector in the back #3
Guys,
regards
heitjer
I don't know anything about the LS tractors, but I'd guess you're right. My Kubotas had such a plug, under the seat, and I used it to power a Shurflo pump on a 50 gallon spray rig.
/ Electrical Connector in the back #4
is that the 7 pole connector on the back? this is the diagram for my xr4046hc which i would think will be the same. Hope it works for you. just use a 12 volt test light to confirm. 20140317_085141.jpg
/ Electrical Connector in the back #5
This is probably a stupid question but what type of male plug insert does that take? Is this a typical 7 pin type trailer plug or is it some kind of European type of plug? I have wondered this for sometime but it has never came up, and I didn't need it yet but is seems pertinent.
/ Electrical Connector in the back #6
they show in the book two versions, , the European one and the ASAE one. The Asae one I believe is American SAE.
The Plug is the same one that is used on semi tractors for their trailer plug in. I tried it, but all my stuff that I would pull is the flat pin rv style so I replaced it with an rv receptacle. the issue that I had was after removing and replacing the round pin to the flat pin receptacle, I found the little plug in behind it to tie it into the loom and the wires are extremely light gauge. I am going to run an additional wire from the battery back to the plug with some #12 gauge wire and a new fuse so that I won't get a meltdown if I want to run a pump or anything that has a heavy power draw yet I still want to be able to just plug it in. this way I will be able to power different items without worrying.
/ Electrical Connector in the back #7
This is a 7 "pin" European plug, not to be confused with a 7 "flat" RV plug. I use a utility trailer to haul hay and picked up a conversion plug to go from 7 round to 4 flat at TSC. I made a jumper to go from the trailer light plug to the adapter. All my trailer lights and signals work.
/ Electrical Connector in the back #8
Duh... I forgot the manual had that image!
/ Electrical Connector in the back #9
Are you sure it is European or just a round 7 pin like you get on most trucks now a days with a trailer tow package?
/ Electrical Connector in the back #10
The last time I was in a U-Haul place, I noticed they have a lot of the conversion plugs.
/ Electrical Connector in the back #11
its a 7 pole , round plug , same as on my big truck.
you can get them at most truck stops , parts houses etc.
/ Electrical Connector in the back #12
That is what I was looking for. I guess I could have just looked but it is just so dammed cold out still. It was 27 this morning still I am soooooo tired of winter, not supposed to get over 35 on Thursday that is the first day of spring. I think someone up there forgot to turn the page on the calendar!
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
2023 VIRNIG RBV50-72" HYD BRUSH CUTTER (A60429)
2023 VIRNIG...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
2014 FREIGHTLINER CASCADIA SLEEPER (A59904)
2014 FREIGHTLINER...
2019 JCB 509-23TC TOOL CARRIER TELESCOPIC FORKLIFT (A60429)
2019 JCB 509-23TC...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
