Electrical Connector domestic vender help!
   / Electrical Connector domestic vender help! #11
These guys specialize in mostly motorcycle electrical supplies but might be a shot.
Main
   / Electrical Connector domestic vender help! #12
   / Electrical Connector domestic vender help! #15
If he cuts anything off the seat, he can't return it if it doesn't work out as a comfortable seat.... ;)
   / Electrical Connector domestic vender help! #16
Why not use 6 wires with male tangs on their ends to connect to the other female tangs.
That's what I would do, and one benefit in this case is that you can most likely slide the blades out of that plug pretty easily without breaking anything. So you could put back to normal if the seat needs to be returned. Normally you can use a thin awl or probe/pick to release the locking tabs holding the blades in, and they will slide out easily.
Thanks guys. As it is, I'm paying the shipping and restocking fee and sending the Grammer seat back.
   / Electrical Connector domestic vender help! #18
be sure to use dielectric grease.
   / Electrical Connector domestic vender help! #19
If you still have your seat here's another # to check from mousers.
571-480003-5 $1.09 + 7.99 shipping ups.
That sure looks like the plug. The seat isn't going to work out for me and I plan to return the seat on Thursday. Even so, thank you for your leg-work!
Honda ES 6500 Generator (A55973)
Honda ES 6500...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
