Electric weedeater
/ Electric weedeater #1
Walkin Horse
Platinum Member
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
Has anybody had any experience with a cordless weed eater. Looking at the Echo at HD. Should I just stick with a gas one.
/ Electric weedeater #2
Can't speak to the echo trimmer, but I just purchased at 36 volt stihlcordless trimmer and it is awesome. I doubt I'll hardly use my gas again it works that well.
/ Electric weedeater #3
If or when my Stihl gas model dies, I'll sure be using a cordless electric in the future.
/ Electric weedeater #4
Check out the other threads on this topic. The new Dewalt 40 V trimmer should be considered before you decide.
/ Electric weedeater #5
I have the cheapie Ryobi 18 volt cordless, and it does 99 percent of all I need done.. It was $39. I already had a set of batteries. It won't eat brush, but grass and ordinary weeds are no match for it. I am usually tired before the larger lithium battery is, and it is lightweight, quiet, makes no fumes and pretty much aggravation free. I have kept my gas machine, but I haven't used it in a year.
I think if you had one of the more powerful cordless machines as mentioned above, I doubt you would need a gas model at all.
/ Electric weedeater #6
I have a 20v(given to me) and even with 3 batteries two of which fit my drill, I use them all up just trying to clip around the driveways and sidewalks. Batteries work for my drills but not for a weedeater with the amount that I have to do. That weedeater needs to go to the flea market. When I get started weed eating, it is sidewalks, fence line (1/4 mile if I do it all), around all the trees (about 100) and I will burn 1-2 tanks of gas doing it, more if I do the drainage ditches where the mower cant go and wet areas around the pond overflow.
For folks with a 20-50 foot driveway and nothing else, a battery powered one may work
Here is my review. I bought the cordless Echo at HD for $269. 90 days to return it if it's junk.
1 hour charge on the 58v battery. I had a little trouble at first with it running. It would run 30 sec and quit. Monkeyed with the battery then it finally worked good. 2 speeds power and battery saver. I ran it on power most of the time. I ran it about 70 mins around the shop sheds and house. I did the dog pen and the horse fence at the house. It still had power when done. I put it back in the charger. Mixed some roundup and sprayed everything around the house and shop.
Then I took it up to the barn and used it. I mite have used it a total of 90 mins there and down the drive way fence. Around some culverts and drains. It still has power.
This is the first time I have done any weed eating this year. Some of the grass was wet and heavy. If you overload it, it will cut off. It did everything I needed with battery to spare. It covered for 5 years and the battery is too. It's as heavy as a gas model. But doesn't vibrate as bad. I like it and it better than a gas so far.
Sent from my iPhone using TractorByNet
/ Electric weedeater #8
I am in the process of getting the Oregon. Actually I am getting the 40 volt pole saw, and so I was interested in the trimmer to better make use of the one battery. I heard that the service manager says these trimmers are junk, although I did not find out why. I'm guessing, just no good for commercial use. Anyway, they have one and I am getting it for NOTHING! Can't beat that!
I will report my findings.
/ Electric weedeater #9
I would rather have a gas. I really don't see any advantage to a battery powered weed eater. I sadly use my weed eater 2-3 times a week.
/ Electric weedeater #10
Well, got my 40 Volt Oregon trimmer today as a companion to the pole saw.
Again, I was warned about the quality. They said it is akin to B&D homeowner stuff.
Well getting home, I just had to try it. I am quite impressed with the way it works. Of course, I have no clue about battery life at this point. It will cut the kind of grass I mostly cut. Just around the many trees I mow around and buildings. No hillsides or fence lines and nothing older then a few weeks growth.
It is quiet. Nice to be able to eat weeds without hearing protection. I love the way it just switches on when you actually need it and then off when you don't.
As long as the battery life is reasonable, I won't mind if it quits a litle prematurely. I have a short attention span for such activity anyway.
Also, I suspect it won't damage the trees as much as my gas powered jobs.
Shall see,
/ Electric weedeater #11
I bought the Kobalt 40 max on the suggestion of a fellow forum member and he didn't steer me wrong. It works every bit as good as the Bolens gas powered that it replaced and batteries last at least 45 minutes of cutting. I have two batteries and with 3 acres of yard, 600' of drive, 3 buildings and about 250 trees, I've never needed for a battery. They charge in 1 hour.
/ Electric weedeater #12
I have had a Black and Decker 20V cordless for a couple of years now. Does a great job. use in on the 2.2 acre yard and it does a decent job on farm fence row on the north side of the yard. Came with two lithium batteries and I can do everything on them with about half the second battery charge left. One of the 36V or 40V varieties might do the job a little quicker and maybe on just one battery, but this B&D was on sale and a great value.
/ Electric weedeater #13
Comments deleted on account of learning new information
2004 STRICK 53X102 T/A DRY VAN TRAILER (A59914)
2004 STRICK 53X102...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2005 Butler pole trailer (A62679)
2005 Butler pole...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
