Electric Tee Switch for Hydraulic lines
   / Electric Tee Switch for Hydraulic lines #1
gvw
Central mountains of Colorado
JD4700
Have any of you used or know of a electronic actuated tee switch for a hydraluic line such as on your loader bucket. Saw a hydraulic driven post hole digger at a local show - guy selling them had a switch in the bucket line where he could use the line for two different items - man was that neat - he had switch on side of loader joy stick that he could thumb and then use the lateral movement of the joy stick for another device such as the spin on the hydraulic post digger. Appears that the flow rate of my 4700 is marginal for a hydraluic post digger - may have to sell and go up a tractor size - if only I could afford to - WOW!
   / Electric Tee Switch for Hydraulic lines #2
JD makes a electric diverter valve for the 10 series,(4410). They also make a unit, ???? valve,can't remember correct name that came with a set of couplers. Hydraulic companies also have diverter valves,and multiplers.
2018 Bobcat T595 (A50120)
2018 Bobcat T595...
2018 Honda CR-V LX SUV (A50324)
2018 Honda CR-V LX...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
Toyota 42-6FGU25 Forklift (RUNS) (A50774)
Toyota 42-6FGU25...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
