Electric pump issue
   / Electric pump issue #1
Streetcar
Veteran Member
Cincinnati ,ohio
John Deere 870
I bought a small pump. The used pump had no wiring for power supply.pump runs n reverse, no matter how the lugs are wired. Help
   / Electric pump issue #2
What kind of pump?
Household well water pump?
DC 12 volt RV pump?
diesel transfer pump?
bilge pump?
If an AC pump , switching wires won't help (unless U do internal changes, and that on only some versions)
If DC then it should reverse rotation.
We obviously need more info to be of assistance.
110 ac transfer pump.
Pump was used to fill tank from pond in previous life
Impeller is running backwards with little flow
   / Electric pump issue #6
There are a very few 110 volt motors that are reversible, but most are not. If it is reversible there should be a wiring diagram on the nameplate or in the connector box to show you how to reverse it.
   / Electric pump issue #7
model numbers for pump would most likely help and pictures as well.
some pictures and explanation of how you have plumbing ran as well.
you might have an air lock, might not have pump primed, might be using smaller pipe that what is needed. might not have fittings tight or done properly. again pictures would help along with model number of pump. and possible pictures of wiring.
   / Electric pump issue #8
If the impeller is running backwards, your right, somehow your motor has Reversed
Send us some pictures...you know your phone has a camera...lol
Have you tried Googling this?
I found this ....Typically an electric motor running in reverse direction is caused by (in order of probability)
A failed electric motor starting capacitor
A single speed single-phase motor leads are reversed on the motor's start winding connections
A single-speed 3-phase electric motor has two of its supply leads reversed
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2005 JohnDeere 644K (A50322)
2005 JohnDeere...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
