Electric Pto engagement
/ Electric Pto engagement #1
Clint199
JD 4500 w 460 loader and MF 230
Hello, I have a JD 4500. It has an electric PTO engagement pull knob. Everything works correctly.
My question/concern is when I am using my bush hog type mower, when I engage the mower even at low rpm’s it is a violent slamming sound and seems that the dump of torque on the pto shaft might cause damage to the mower or to the gearbox of the tractor. Am I doing something wrong or is that the way an electric PTO works?
/ Electric Pto engagement #2
It's just the way it works. The mower can take it. Keep engaging it at low engine RPM, it's about the only thing you can do to help it.
/ Electric Pto engagement #3
Try slowly rotating the PTO knob until it just starts to turn the pto/implement then release it a second then re-engage it, that's how I do mine. That way it gets the pto moving but doesn't apply full force/torque. I also only engage or dis-engage the pto at idle, making sure the engine and pto have slowed to minimum speed.
Thanks—Rather ask than tear something up
/ Electric Pto engagement #5
There should be orifice in the PTO circuit to control how abruptly the PTO engages. This is kind of a balancing act on allowing the clutch to slip a little but not so much you burn the clutch plates.
/ Electric Pto engagement #6
The initial rumble when you turn on the Pto with a brush hog attached, are the knives. They are kind of "folded" in on the stump jumper and have to sort themselves through centrifugal forces.
2017 FORD F-450 XL BUCKET TRUCK (A60430)
2017 FORD F-450 XL...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
1667 (A57192)
1667 (A57192)
2013 NISSAN NV3500 CARGO VAN (A59905)
2013 NISSAN NV3500...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
