Electric Problem??
   / Electric Problem?? #1
rstars93
Anza CA
3032e
I have a 3032e tractor. I parked it on a hill when the fuel level was low. When I tried to restart there was no response. There is an error code saying fuel off on the screen when I attempt to start. I am now on level ground with plenty of fuel but cannot get past error message. Help!!!
   / Electric Problem?? #2
You may have to bleed the system.
   / Electric Problem?? #3
Try disconnecting the battery for about 5 minutes. This may clear the code.
Did you run it out of fuel? Then you may need to bleed the system like Murph said
I was so hopeful that zebrafive was right. The tractor was running strong when I shut down. I took the time to put both my box scraper and loader down prior to shut down. Having said that, the battery disconnect did not solve my problem. Can you direct me to instructions for "bleeding"? Thank you for your help. Randy
P.S. Any chance what I did could have caused the fuel solenoid relay to go out?
2002 Genie Z34/22 34ft Electric Telescopic Boom Lift (A51691)
2002 Genie Z34/22...
Top Hat Bumper Pull Trailer (A53117)
Top Hat Bumper...
1980 Case IH 2wd 67hp tractor (A53473)
1980 Case IH 2wd...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2016 Dodge Caravan (A51694)
2016 Dodge Caravan...
