Electric Problem??
/ Electric Problem?? #1
rstars93
Anza CA
3032e
I have a 3032e tractor. I parked it on a hill when the fuel level was low. When I tried to restart there was no response. There is an error code saying fuel off on the screen when I attempt to start. I am now on level ground with plenty of fuel but cannot get past error message. Help!!!
/ Electric Problem?? #2
You may have to bleed the system.
/ Electric Problem?? #3
Try disconnecting the battery for about 5 minutes. This may clear the code.
Did you run it out of fuel? Then you may need to bleed the system like Murph said
I was so hopeful that zebrafive was right. The tractor was running strong when I shut down. I took the time to put both my box scraper and loader down prior to shut down. Having said that, the battery disconnect did not solve my problem. Can you direct me to instructions for "bleeding"? Thank you for your help. Randy
P.S. Any chance what I did could have caused the fuel solenoid relay to go out?
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
3146 (A63117)
3146 (A63117)
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
CAT CB34 (A60462)
CAT CB34 (A60462)
