electric motor, lights, et al plug question
   / electric motor, lights, et al plug question #1
63DH8
Parkland,Washington State, U.S.A.
Massey Ferguson GC1725M Bolens TX 1504 (G154) 1957 John Deere 420C crawler
   / electric motor, lights, et al plug question #2
I use the two prong trailer light plugs available almost anywhere. Good for 15 amps or so and cheap.
   / electric motor, lights, et al plug question #3
Anderson/Forklift plugs are real cool, but you will pay allot for the coolness /forums/images/graemlins/shocked.gif
There are really designed for high-current applications, such as battery strings, chargers, winches, etc. IMHO there are overkill for lights or sprayers...
   / electric motor, lights, et al plug question #4
The mid priced option might be the electric trolling motor connections used when wiring bass fishing boats. they can handle moisture and a failry heavy electrical draw.
Try Cabela's (marine catalog or web site)
or Boat stores like West Marine or Boaters world
   / electric motor, lights, et al plug question #5
The 2 prong trailer light connectors work for me. One nice thing about them, if wired correctly, is that you can plug the sprayer into your flat 4 trailer connector, toss the tank in the back of your pickup & drive around spraying fences, driveways etc. Mine just happens to turn off & on w/the vehicle headlight switch. I've also wired a 2 prong connector into my Dixie Chopper zero turn mower so that the sprayer has power when tossed into a tow-behind garden cart.
   / electric motor, lights, et al plug question #6
In my opinion, I would go with the heavy duty Anderson connectors you posted a picture of. They aren't that expensive. I bought mine from Cabelas. They were only about 15 bucks for a pair. I put a set on my Kubota L3400. I can plug in lots of accessories such as a sprayer pump, work lights, spot light or whatever. As a matter of fact, I have a 1000 watt power inverter rigged up with that connector which has come in extremely handy on remote parts of my property.
I have even jump-started my ATV a time or two using this connector.
I have mine conveniently mounted under the rear of the seat to the metal channel that holds the fender.
I have a 40 amp automotive breaker mounted in the battery compartment and from there I ran 8 or 6 gauge wire (I forget) to the connector.
Within reason, there are tons of possibilities if you use the heavy duty connector.
Just my 2 pennies.
Dave
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
