electric fence
/ electric fence #1
MDSteve
Clements MD
Kubota 3710
This will be my first electric fence project. We are adding an extra pasture for this winter to try and let our other pastures rest and not get muddy during the winter rains. Our plan is to run an electric fence for about 3 acres thru the woods just to give the horses somewhere to walk around during the winter instead of being stuck in the stalls. Currently I can't find any fence boards so this will only need to last the winter. Should I get a battery fence charger or a 110 volt one? I would like to use tape instead of wire but is it all the same or are there diffrent grades? I have been looking thru Jeffers and state line tack in the bathroom for the past few days but would like some input from folks that have done this before.
Thanks,
Steve
/ electric fence #2
Horse Guard Fence with a Parmak solar charger. See attched picture. They have solutions for using wooden posts or T posts.
/ electric fence #3
we live in a pretty windy area, so we we advised to not use the tape...we ended up using the Polyrope and the little Parmak solar charger...the fence is 4 lines around 6 acres or so, with several cross field lines as well...installed for 2 years now...whole system works pretty well
/ electric fence
Thanks guys. Keep the info coming. Seems like the solar charger is the way to go. I will have to continue looking at the tape or polywire. I thought the tape would be easier for the kids/horses to see but I think everyone will get zapped at least once to learn not to mess with the fence.
Steve
/ electric fence #5
If you have 110 close enough to use I'd go with the 110 volt models. You get more bang for your buck. I currently have 4 fence chargers going. Started out with one. Those mile figures are misleading. I have one Range Master 12.5 joule output (parmak) one galleger 800-5 joule and two Kencove k6-6 joule chargers .
The key to any good electric fence is voltage. You want the animals to stay in,make sure it's HOT. With cattle I want no less that 3000 volts on the wires. The key to any good fence charger is the ground rod system. For a charger to operate correct it needs one 8 ft. ground rod per 1000 volts of output. When to soil is moist you don't need that many rods but it does get dry and if you don't have a proper ground system the charger isn't much good.
I know nothing about horse fencing but I do have 130 acres fenced in with High Tensile wire for cattle. Here's a site with lots of information for your needs. I've been buying from these folks for 14 years. You need it, they got it and are very very good on a timely shipping. Great folks to deal with. I'm sure there are others as well. http://www.kencove.com/ They also have a large selection of horse fencing supplies. Even if you don't buy from them spend some time reading what they have in their free fence guide. They know electric fence.
/ electric fence #6
The white polyrope is pretty visable.. I just took some down for a temp enclosure for steers.. ran 3 strands on t-posts.
/ electric fence #7
i've repaired fence chargers as a sideline for about 20 years, and i agree 1000%. if 110 is available, use it instead of a solar unit. a neighbor put in an electric fence just like the link described, lasted several years, then he went back and put in a barbed wire fence, the electric fences work great on most critters, but the web wire or barbed wire works on all but the worse.
heehaw
/ electric fence #8
I have about a mile of electic fence. I would use the 110 if you can but the battery ones work ok. I prefer the battery ones running off of a car or deep cycle over the solar ones. The solar ones for the most part use a very small battery and some are only 4.5 volts. I have used all types of wire. Steel and aluminumin. I like the poly rope the best. It is the strongest and last much better than the tape. The tape takes special insulators and the poly rope works with standard insulators. As already stated grounding is the key to a good fence.
/ electric fence #9
MDSteve,
Let me second Charolais recomendation for Kencove. They are great to work with and sell high quality, fairly priced products. I have the same size property you do, and I am just finishing my high tensile fence for seven acres. I installed four lines of standard H.T wire for the bottom lines and used Kencoves 'Hotcote' line for the top line. I'm charging lines 1, 3 and the Hotcote, and using 2 and 4 as grounds. Since pasture is surrounded on four sides with pine forest, I decided to use the Hotcote line on top as a sightline. The plain wire is hard to see against the forest background but the Hotcote is very visible to our horses.
Some random thoughts to keep in mind:
Your hot lines will work only as well as your ground. Make sure you have good, deep set ground rods.
If you're farther than 150 ft. from an outlet to your charger, consider a solar/battery charger. The voltage drop on an AC unit will not let it work to its full capacity.
Try and stay away from electric tapes. All the ones I've seen tend to sag in the wind alot more than a wire style.
Good luck. Post pics when the project is done.
/ electric fence #10
<font color="blue"> The solar ones for the most part use a very small battery and some are only 4.5 volts. </font>
The Parmaks use either 6 or 12 volt batteries. Click Here.
/ electric fence #11
I run all wires hot. In ideal conditions my voltage stays around 9,000 on the Range Master. The other 3 run 5,000-6,000 vlots. I like the way Kencove test there products they have for sale. That way they can answer questions on any product they sell.
/ electric fence
The Kencove site has been great. This pasture will be sectioned off from the Barn so 110 is not a problem. Is it a big no no to mount insulators to trees for corner posts. I hope to find some fence boards by spring to replace the wire with.
Steve
/ electric fence #13
I use a lag corner insulator on trees and in wood post as well with HT 12.5 wire. http://www.kencove.com/ShopDetail.php?recordID=ILC They're strong and easy to install. Regular nail on insulators on trees are OK for short term. Trees grow faster than we think. Found out pretty quick that a board is needed for the line insulators and fasten the board to the tree.
/ electric fence #14
</font><font color="blue" class="small">( Here's a site with lots of information for your needs. I've been buying from these folks for 14 years. You need it, they got it and are very very good on a timely shipping. Great folks to deal with. I'm sure there are others as well. http://www.kencove.com/ )</font>
Thanks to Charolais and MFL for their advice on Kencove. I called them concerning a problem with deer 'rutting' against my Leyland Cypress trees. Even after closing hours, (I called a few minutes before 5 PM) they explained what I needed, took the order, and will ship everything out Monday morning. Very customer friendly personnel.
/ electric fence #15
Glad they were able to help srs. I like their policy on what they sell. They'll use the product and tell you straight up the good and bad of it. With that type of testing you get good service and information. Not a hot ad. making claims.
Then there's the good friendly people you get to talk to on the phone. Just like a neighbor down the road. Every time I call I always get asked what's the weather like down there in Va. You add that to good prices,good supply in stock and answers you can depend on and you got a great outfit to deal with. And did I mention prompt shipping? /forums/images/graemlins/cool.gif I depend on them.
Good luck with your fence.
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
Caterpillar 235C Excavator Service and Operation Manuals (A63117)
Caterpillar 235C...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2019 FORD F350 4X4 PICKUP TRUCK (A59912)
2019 FORD F350 4X4...
2012 VOLVO SD105DX SMOOTH DRUM ROLLER (A64279)
2012 VOLVO SD105DX...
