Electric connections BX2200
   / Electric connections BX2200 #1
g42guy
Minneapolis, MN
Kubota BX2200, '55 Farmall Cub, '57 Ford 640
Under the seat of the BX there is both a male and female exposed connection. The female has power to it. Is the male a ground?
I want to hook up one or two Plug-ins (cigarette light type) for portable work lights and such.
Thanks
Guy
   / Electric connections BX2200 #2
It is a ground in the sense that it goes to a non existent switch to turn on a light on the dashboard. It isn't used on the BX tractor, but the harness is the same for other Kubota items. Just tape it off and forget about it. It, like your appendix, serves no useful purpose. /forums/images/graemlins/grin.gif
But Can I use the power connection to hook up my plug-ins? And if the other IS grounded, it would just make a nice clean install. ?
   / Electric connections BX2200 #4
The powered wire is for an auxiliary light or any thing else that you want it for as long as it doesn't draw more than 15 amps. The wire that has no power to it, can not be used at all. You can ground to any metal on the tractor, so a ground isn't much of a concern for location....
   / Electric connections BX2200 #5
On my BX1800 I used the two wires for my lights. I didn't check with a meter to see if it was grounded, just assumed. They worked fine all last Winter. Now Junkman has me wondering so I will have to go out and check it.
You can see in this photo my hookeups. I ended up using a trailer plug set up instead of the cigarette lighter plug, but I am not using for anything but lights.
   / Electric connections BX2200 #6
And here is the power wiring under the seat.
   / Electric connections BX2200 #7
I used those 2 wires with a inline switch and blow a fuse when I turned the switch on. Like junkman said use the hot wire and ground to tractor and it works ok
   / Electric connections BX2200 #8
My BX2200 is a coupla years old - I used the two wires under the seat, one is hot, the other is ground - I connected them to a cigarette lighter socket and use it to power my magnetic work light and sprayer, but not at the same time.
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53472)
Chevrolet C8500...
