Electric Clutch as Slip Clutch?
   / Electric Clutch as Slip Clutch? #1
KP2654
LS XR4150
Just wondering, since I have an electric PTO clutch, do you think it has been engineered to slip before damage to the tractor occurs? I have a brush cutter with a slip clutch, but I was thinking that surely the tractor has been engineered so that the electric clutch will slip before damage occurs to the PTO driveline. Thoughts?
   / Electric Clutch as Slip Clutch? #2
Welcome to the forum. :thumbsup:
You have a electric over hydraulic PTO clutch.
Basically you have a clutch pack, pretty much like a clutch pack on a automatic transmission. When you flip the switch, it energizes a solenoid valve that will then apply pressure to the clutch pack to engage. When the flip is Off, a spring applies a brake.
This setup doesn't work as a slip clutch. You still need a slip clutch to prevent damage to your tractor.
10-4. Exactly what I was looking for. Thanks for the info!
FAKE (A52472)
FAKE (A52472)
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
SAGE AIR COMPRESSOR W/ 100 GAL FUEL TANK (A52472)
SAGE AIR...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
