Electric Clutch as Slip Clutch?
   / Electric Clutch as Slip Clutch? #1
KP2654
LS XR4150
Just wondering, since I have an electric PTO clutch, do you think it has been engineered to slip before damage to the tractor occurs? I have a brush cutter with a slip clutch, but I was thinking that surely the tractor has been engineered so that the electric clutch will slip before damage occurs to the PTO driveline. Thoughts?
   / Electric Clutch as Slip Clutch? #2
Welcome to the forum. :thumbsup:
You have a electric over hydraulic PTO clutch.
Basically you have a clutch pack, pretty much like a clutch pack on a automatic transmission. When you flip the switch, it energizes a solenoid valve that will then apply pressure to the clutch pack to engage. When the flip is Off, a spring applies a brake.
This setup doesn't work as a slip clutch. You still need a slip clutch to prevent damage to your tractor.
10-4. Exactly what I was looking for. Thanks for the info!
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
ATTENTION! PLEASE READ (A50121)
ATTENTION! PLEASE...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
