Elect/Hydraulic Dumping Trailer
   / Elect/Hydraulic Dumping Trailer #1
mwells4654
Antlers, Oklahoma
International 404 & Shibaura SD2600
I have a small dumping trailer that currently is a power up gravity down and I want it to be power up/down. The cylinder is dual but only has one hose going to it from the electric pump assenbly. What would be the easiest way to convert the system? Thanks in advance for any advice.
Melvin L. Wells Jr.
   / Elect/Hydraulic Dumping Trailer #2
2 hoses and 1 spool valve and a return to the reservoir
   / Elect/Hydraulic Dumping Trailer #3
What kind of valve are you using now.
If it is a SA spool, then you have to get a DA valve.
If it is a DA spool valve, then remove the plug from the one work port and use two hoses to the cyl.
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2019 Yamaha Electric Golf Cart (A51573)
2019 Yamaha...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
