Spreader El Cheapo sand spreader
/ El Cheapo sand spreader #1
jdgreg
Warrenton, Va
Been reading all the spreader posts with interest. Here in N. Va, we dont get a lot of ice, but do occasionally. When we get it, used to use my lawn tractor (with chains) and pull my lawn spreader (brought from TSC) to put a little sand down. Note that I've never needed or used more than a half dozen or so bags of sand. Given my infrequent need of a spreader, it doesnt make real sense to buy a 3PH spreader, new or used.
So I came up with the idea of welding a tab on the back of my blade so that I could quickly and easily hook up the spreader, lay down a few bags, then unhook it.
Anyone done something similar?
/ El Cheapo sand spreader #2
Some people weld on a 2" receiver hitch. That gives you the flexibility of attaching nothing, a drawbar hitch, a carryall, boompole, or whatever. I plan to install one on my boxblade, so I can move the trailer if/when I need to.
Costs more, but gives you some flexibility.
Your tab idea will work fine.
ron
/ El Cheapo sand spreader #3
Yes, I did the same thing. Works fine. Only bad part is that it is very hard to turn around in the limited space at the end of my drive. I usually have to unhook the spreader and then turn around.
I thought about welding a tab, or a receiver, but I couldnt come up with a location that I liked, or thought wouldnt be a problem if I used the blade backwards to push snow or dirt.
So I came up with an extension bracket for the spreader. It bolts up using the original bolts that hold the pieces together that the pin goes through. This way, I can easily unbolt it and take it off when I use with my lawn tractor (unless it doesnt interfer with anything).
I didnt paint it, cause I wanted to make sure it would hold when I actually used it, probably paint it this spring.
Here's a pic with it mounted. It uses one of the pin holes for the blade angle .
It also makes a good handle for moving the spreader around. /forums/images/graemlins/wink.gif
2026 GIYI FB77 Feller Buncher Skid Steer Attachment (A66734)
2026 GIYI FB77...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
2005 Freightliner FLD120 Ambulance (A66736)
2005 Freightliner...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
x (A68191)
x (A68191)
2019 MACK PINNACLE (A67714)
2019 MACK PINNACLE...
