eHydro -- No reverse in 2WD
   / eHydro -- No reverse in 2WD #31
I will add that my tractor has popped out of mid range twice in the 3 years I've owned it. It makes terrible sounds until everything stops moving, but wouldn't call it a chatter.
UPDATE --
I tried to capture the malfunction on video and could not because it's not malfunctioning anymore -- In 2WD with Load Match off, the engine bogs down to a stall under load, as it should, rather than doing what it was doing at the start of the thread, which was for the rear axle to become de-powered while the hydro fluid is diverted with no change in engine RPM.
I'm still heading for deep maintenance and diagnosis in another month or two when I can take the tractor out of service for a couple of weeks. Something just ain't right ... hopefully we can narrow it down.
2018 JCB 409T4 WHEEL LOADER (A52707)
2018 JCB 409T4...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
MCCORMICK T110 MAX TRACTOR (A57192)
MCCORMICK T110 MAX...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2012 CATERPILLAR 308E CR EXCAVATOR (A52707)
2012 CATERPILLAR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
