EGR delete on new turbo Kubota?
   / EGR delete on new turbo Kubota? #41
Thanks, that's a good idea. I think you would definitely want an EGT guage if you start adding more boost. Not sure if there would be much to gain without adding fuel also? I think water/methanol injection would be a sweet setup. Lower EGT's, more power, better fuel economy. On cab models, you even already have the washer fluid tank!
Have you noticed any fuel economy/ performance difference since unhooking the pressure line to the EGR valve?
Can't say I have notice much economy difference although it sure is not worse. I have not run it long enough in one stretch to know for sure.
But for the sake of argument, it is better.:laughing::laughing:
   / EGR delete on new turbo Kubota? #42
If the stock wastegate opens at 8 psi then stock fueling probably won't support much over 10 psi. I'm wondering what the stock head gasket and head bolts will reliably support before the bolts stretch and the head gasket goes? When I finally get mine I think all I'm going to do is remove the egr and adjust the timing, although blocking the wastegate and cranking the fuel up would be fun.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
2019 Takeuchi TS80V-2 Skid Steer, PIN# TKV80201102, Deutz Diesel Engine, Joystick Operating (A59076)
2019 Takeuchi...
2017 Ford F-550 Cab and Chassis (A56858)
2017 Ford F-550...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
