Ego zero steer mower review
   / Ego zero steer mower review #291
My first mower, a HusquvarnaI Rider 155, came only with a stamped deck. My mowing needs increased, so I needed a second mower as well. also had reservations about buying another mower with a stamped deck, so I bought my second mower with a 7 ga fabricated deck. Unfortunately the second mower with the better 7 ga deck crapped out after 5 years. On the other hand, the Husqarna Rider with the stamped bio-clip deck has lasted 21 years, and still cuts beautifully. I does, however, has a couple of really thin spots that are rusting through; not so much as to allow clippings to fly, but those days are ahead.
In short, I think the stamped decks are better designed than the fabricated decks. My thinking is that if a stamed deck would hold up for >21 years, and still doing just fine, I would not opt for a fab deck at a higher cost again.
I think the point demonstrated is that neither manufacturing method guarantees durability.
There are plenty of poor quality stamped steel mower decks. In past decades it was common to see a riding tractor parked by the curb free for the taking, without a mower deck. The mower deck failed, owners found out how much it cost to replace, bought a new mower instead.
   / Ego zero steer mower review #292
Spoken like an engineer.
My Chevy Silverado pickups appeared to have been built substantially heavier than either of my Ram pickups. But neither Ram has ever broken down on me, ever, whereas those Chevy pickups left me stranded on more occasions than I could ever care to remember.
"Well built" is almost never in the obvious details. Or looking at my old Silverados, heavier sheet metal, hubs and control arms don't mean squat, when your 4wd solenoids, ECM's, exhaust, or brake lines all fail on relatively-new trucks.
Every system has a weak link, and beefing up other parts of the system does very little to resolve that.
   / Ego zero steer mower review #293
So, I just called the aforementioned cousin, who's mowing 2.5 - 3 acres with his Ego. He says he's in his 4th season now, and if there's been any degradation, it's not enough that he's noticed it, given his property size / mowing frequency.
I'm sure the batteries degrade, of course they do. But I don't think it's anywhere near quick enough to be thinking on a 3 year time scale, for most homeowners with a zero turn. They're actually warrantied for 3 years, so you have to expect their fail rate must be near zero, on that time scale.
I have a fair amount of Dewalt 20V and 60V batteries that get used a lot. A couple are over 7 years old. I havn't replaced any.
   / Ego zero steer mower review #294
For some reason (probably cost, American auto makers use steel brake lines instead of Ni-Cop brake lines like the Europeans use on their automobiles and trucks and steel brake lines eventually corrode, especially up here in the north so you have to eventually replace them with Ni-Cop brake lines. Had that happen on my 97 F350 that never sees snow but still corroded. The brake line that feeds the rear axle failed and I replaced it with Ni-Cop which will never corrode. Had to replace ALL the brake lines on my wife's long gone Ford Transit as well. I like Ni-Cop as it's easy to work with, unlike rigid steel brake lines. Easy to bend (with a proper bending tool) and lasts forever. Ni-Cop lines don't corrode and every auto parts store sells it in various diameters and it's easy to bubble flare or double flare (again with the correct flaring tool).
   / Ego zero steer mower review #295
So long as you remove the caked on grass cud from the underside of a deck during winter layup-storage and keep the underside of the deck painted or oiled as the case may be, a stamped deck or a fabricated one will last probably longer than the engine will.
I keep my wife's ZTR as well as my Kubota (fabbed deck and stamped decks) clean in the off season. Hers is 8 years old (stamped deck) and looks as good as when it was new. I do have to replace the anti-scalp wheels regularly but I get them from ASC and those come with molded in grease passages so they get greased which makes them last longer up here in the sandy soil. Her blades do fail every year from the sandblasting they get and it's always the 'kick up' on the blade that erodes off, not the blade itself. I get them from ASC as well. Much less than the cost at the tractor dealer.
   / Ego zero steer mower review #297
Gotta keep the Chinese in business right? Last time I checked all the EGO stuff was made in China. Maybe when the Chinese build the assembly plant in Mexico and start flooding the US market with their automobiles and light trucks, you can off your little Bronco and buy one of theirs instead. I'm sure they will be very competitively priced.
The Chinese are building that plant for the sole purpose of evading the import duties. Sort of why American automakers build their stuff in Mexico. Cheap labor and no imposed duties.
Why Volkswagen is contemplating closing some of their German auto plants. The Chinese are flooding Europe with their vehicles and VW, being the largest manufacturer of vehicles in the EU (they employ over 650,000 workers in direct manufacture as well as indirect) are contemplating a severe downsizing. Europeans just like here, love a bargain but at what cost overall?
I'm sure you like the electric mower, I looked at them at Home Despot some time ago, they just don't work for my application and my utility bills (electric) are high enough as it is and not getting any cheaper either. Michigan is kind of unique in that utility (electric) providers can increase rates based in anticipated use and the MPSC usually rubber stamps their increases. You live in Michigan, just like I do. Between utility bills and insurance costs here, it's kind of hard to stay solvent, especially in these inflationary times.
Just keep the underside of the deck clean while it's parked for the winter and you'll be good. You must be a lawnee. I think I've mowed the farm yard and the rentals 4 times this year, but then I'm not a 'lawnee' or a 'yardee' like my wife calls you people. Guy down the road is one. Has to mow his patch every week at least, but he has a gas mower, not a sparky one. he keeps looking at my Kubota diesel mower but I don't believe he can afford the price of admission. I can and did.
But you keep talking about the great Chinese tools you like to buy......
   / Ego zero steer mower review #299
I think this observation is largely dependent on your soil conditions. Around here, that deck is rusting all thru the season, our grass is so wet spring and fall. I do try to scrape it clean as often as I can, but we have to mow every 3-4 days in spring, so it becomes impractical, at a point.
Good to know. I’m going to have to check them out next time I need mower parts. Thanks!
I’m not sure how it is today, I stopped going to Europe every year around 2018, and haven’t spent very substantial time there since the early 2000’s. But at least in the late 1990’s into early 2000’s, Germany and most other Euro countries were doing a pretty good job at protecting their manufacturing, by two means:
1. Really promoting a strong “it’s better if it’s made in Germany” ethos. Most Germans truly believed this, at least back then.
2. Imposing strong import duties on items from other countries, with rates scaled to make those items at least as expensive as “made in Germany”. I remember looking at televisions in 1998, and I could buy one made in China or Japan, but they were both going to cost me nearly the same as one made in Germany.
On the flip side, they were really screwing their manufacturers with ridiculous levels of regulation, so I’m not holding them up as some perfect example of how things should be done. Each society and system has its good and bad points.
   / Ego zero steer mower review #300
Milwaukee battery tools are also made in China. But most tradesmen will swear by them.
(Most of their blades, bits and hand tools are USA made)
2013 MACK CXU (A50854)
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
2008 FORD F-350 (A50854)
2008 FORD F-350...
2017 AUTOCAR YARD SPOTTER (A51222)
2017 AUTOCAR YARD...
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
