Educate me please
   / Educate me please #11
I mow about the same size property as the OP.
I need the comfort of mowing with my Kubota. (back issues). Harsh riding lawn tractors are a killer for me.
As long as you aren't trying to cut stumps or saplings and the rough ruts gets raked out a little, a finish mower is what you want. I wouldn't let it get over 6" high and there'd be no need to allow it get that bad.
I did a thread here:
http://www.tractorbynet.com/forums/attachments/175916-so-you-considering-rear-finish.html
You might enjoy it.
   / Educate me please
You might enjoy it.
I used to live in Ohio (born there) and the big difference is here (central coast of CA) the rainy season is in the winter. It also causes the grasses (this is field grass, mind you, not lawn) grow fast, and the soil is too wet and soggy to mow for several months. That is my main concern, if the field grass and weeds get to 24" or so before it dries enough to mow, would a finish mower do the job? I notice this one says to 4 1/2" high, but looking at the design, I could modify the support arms for the wheels and bring that to 6" easily. I don't really need it as a "lawn" mower. I'll try to post a pic of my field.
   / Educate me please #14
Actually, now that I look closer, I'd need the drive shaft also, another $70, plus shipping. That's over my budget by a lot. Thanks for the feedback.
If a 70 dollar shaft is bustin' yer budget, I think you're gonna have a difficult time with tractor ownership. :)
Seriously, though, if you're willing to pick up most/ all of the branches, either beforehand or as you go, & you set the finish mower to its max height for your first pass, it might work OK.
   / Educate me please
Well being retired, and considering the mower is $499, plus 70 for the shaft, plus about $129 for shipping we're sittin on $700 real quick, then throw in another $46 for tax, well that $500 mower just got to 750 real fast. That's also why I bought an old MF1010. At $4000 (with MF1014 FEL and Gannon rotating box scraper) it was pretty much my limit also.
Here's a pic of my "yard". The tall brown things are a type of cattail. Yes it does get soggy down there in the winter.
   / Educate me please #16
The finish mowers like that are very much like a mid mount (belly) mower on some tractors or similar to what you would find on a garden tractor. They would have usually 3 blades which are connected to the gear box by a belt. To do a decent job, the blades need to be relatively sharp. The blades are basicly a heavy lawn mower blade, so they will cut some pretty heavy stuff, but subject to damage it you hit a rock or something. The weight of the mower is just carried by the wheels on all the corners and adjusting them is how you adjust the cut height.
The rough cut mower in the size for smaller tractors has one gear box spinning a spindle with an oval shaped plate. Attached to it is two much heavier blades. The blades are spun out by centrifical force from the plate and really end up acting like one big blade. They rely on a very fast blade tip spinning and the heavy blade to cut. Because the blades are heavier, they can cut heavier material without damage but if you try, you can do it. Most smaller rough cut mowers have just one wheel in the back, sometimes 2 and the weight in the front is carried by the 3 pt hitch.
As others have said, if you can cut it reasonably frequently, once every 3 weeks or so, you would probably be ok with the finish mower. Maybe can borrow a rough cut mower to initially get it under control.
Also, maybe watch craigs list, or check at some of the local farm stores. Can maybe pick up a mower and avoid the shipping.
   / Educate me please #17
Maybe I am reading the ad wrong, but doesn"t it say the driveshaft is included? :confused2:
   / Educate me please #18
Replying to all.. I would use the finishing mower to cut grass, the Brush Mower for anything more.You can cut grass with a Brush Bull, but it is a rough look, not like a finish lawn.
I use the Garden Tractor to mow, the utility tractor to clear brush..
Johno Geo
   / Educate me please
It does say this "Includes quick-coupler PTO driveline shaft" (which I missed:confused2:). Looking at the description, it DOES include the "extendable driveline shaft". duh. Thanks.
I have been looking at craigs list and other local listings for months. I have seen a few, but either over priced ($800+), or too large for my MF1010.
I will continue to do so. I may still order this one even though it is a finish mower, since I have mowed a good portion of this before with my walk behind Hushvarna self propelled. I am aware of the potential for damage as well.
   / Educate me please #20
I am not sure I understand completely what you are wanting to do.
You currently own 3 acres and keep 1 acre as a mowed lawn and the other two goes to tall brush/weeds.
Are you wanting to turn the 2 overgrown ares into a lawn that you mow as often as the 1 acre?????OR are you only wanting to knock it down a few times per year????
If you want it as a managable lawn, then a finish mower is what you want. It will be slow going for the first few mowings, but once established as a lawn, it will be fine.
If you are only wanting to mow a few times per year, I think you are going to want a rotary cutter/rough mower/bushhog. They are a lot faster than a finish mower on just about everything over 8" and or thick weeds. If you plan on waiting on it to be between 12-18" or taller, a bushhog will save you a ton of time. And when it is that tall, even a finish mower won't leave a very good looking yard/field when done.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
