Comparison Educate me: compact versus utility
   / Educate me: compact versus utility #11
Messick,
"Utilities never have a hydrostatic transmission"
Just for the sake of the conversation, (not to be a butthead) how would you classify a Grand L5030HSTC with 853 FEL and an 85 BH? (Besides really nice.)
   / Educate me: compact versus utility #12
Deerefan mentioned a JD 790 as a compact tractor. It is also a utility tractor, so it's a compact utility tractor. There are no hard and fast lines. HP on Compact tractors and on Compact Utility Tractors (CUT) overlap.
You're absolutely right, the line between these types is blurred.
   / Educate me: compact versus utility #13
I believe that before compact tractors were around there were the utility tractors and the row crop tractors with adjustable front axles and reversable rear wheels.
The utilitys being non-adjustable and not considered for crop use.
But I could be wrong /forums/images/graemlins/confused.gif
   / Educate me: compact versus utility #14
</font><font color="blue" class="small">( Messick,
Just for the sake of the conversation, (not to be a butthead) how would you classify a Grand L5030HSTC with 853 FEL and an 85 BH? (Besides really nice.) )</font>
Kubota rates the 5030 as a Compact tractor. This is the largest one they make that is considered a compact. It has the same frame size as the 4330 and 4630.
   / Educate me: compact versus utility #15
Great question. That one does kinda blur the line since it has a cat 2 3pt. It is however still a light weight tractor, with an HST - so I'd say its still a compact. Its drasticly different than any of the M-Series machines, even though its operating loads are on par with some of them.
   / Educate me: compact versus utility #16
</font><font color="blue" class="small">( compact tractor & utility tractor )</font> My friends go by old time thinking, pulling stuff or sitting in fields - tractors.
Stuff in garage or shed - CUTS and lawn mowers.
Thusly, I have attached a blade to mine and let it sit outside. /forums/images/graemlins/grin.gif
-Mike Z. /forums/images/graemlins/grin.gif
   / Educate me: compact versus utility #17
Another key difference (to add to bunch) is the type of chassis. Compacts are built on steel A frames in which you mount the engine and transmission. Whereas in a utility tractor, you would couple the engine to the transmission to the differential and that would be your integral frame, no external frame. I have found that to be my own indicator to make the distinction.
To me, the HP rating can no longer be the sole indicator as the newer compacts have begun to pump out 55HP. Same for the weights which are increasing pushing the 4000lbs, comparable to low end utility models.
Lets not even go in Front end loader ratings which are measured differently between CUTs and UTs.
   / Educate me: compact versus utility #18
<font color="blue"> Another key difference (to add to bunch) is the type of chassis. Compacts are built on steel A frames in which you mount the engine and transmission. Whereas in a utility tractor, you would couple the engine to the transmission to the differential and that would be your integral frame, no external frame. I have found that to be my own indicator to make the distinction. </font>
Like some of the other things that differ, what you said is true for some compacts but not for others. Some compacts do use their tranny, rear end and engine for the frame.
   / Educate me: compact versus utility #19
I like looking at the footprint, and 3pt category. cat 0 is scut.. cat 0/1 is on the edge.. and 1 is cut. cat 1/2 is on the edge, and cat 2 is util.. large cat 2 and up are ag tractors.
That's just my opinion.. etc..
Soundguy
   / Educate me: compact versus utility #20
</font><font color="blue" class="small">( Lets not even go in Front end loader ratings which are measured differently between CUTs and UTs.
)</font>
To my knowledge that has nothing to do with the classification of the tractor and more to do with particular companies choosing to use the more favorable number in their marketing literature even if it is deceptive.
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
Cushman Electric Cart (A55853)
Cushman Electric...
Eagle Weathervane (A55853)
Eagle Weathervane...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
2014 Audi Q5 SUV (A56859)
2014 Audi Q5 SUV...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
