Snow Edge Tamer attachments
/ Edge Tamer attachments #1
Buckchaser
Bradford PA
Massey F 1734
Has anyone on the Forum used or bought the Edge Tamer attachments that attach to your loader bucket to keep it off the ground for snow plowing ? Just wondered how good they work?
/ Edge Tamer attachments #2
The work pretty good for not scraping the tar and for not digging into the lawn or unfrozen ground but I have so much frost here It doesn't matter if I use the cutting edge I don't dig anything up. They leave to much snow on the ground for me.
/ Edge Tamer attachments #3
I have them and love them. They do leave snow and that builds up with each snow fall of course. In usual winters for me I would prob be like Buckchaser. Once the ground is good and frozen take them off. This year we have had snow, then warm weather where it all melts. So each storm has been like the first one. There is a need for them.
I also use them when dealing with the horse manure pile around the farm. Much easier to push that up into a pile knowing I am not digging a deeper hole each time.
They are heavy duty and well made.
/ Edge Tamer attachments #5
In you're location and the manure project I would think they would be an asset to you for sure.
Do you use just one on each end or an extra one in the middle of bucket.?
/ Edge Tamer attachments #7
When I bought mine they only had the 3" and 4" now I see they have a 6". I bought the 4" and only got two. My bucket is less than 5 foot wide. There has never been a time when I wished that I had another one in the middle. I put them about 1/4 of the way in from the outer edge of the bucket so there is less distance between them across the center line. I mainly do this so when I am putting them on or taking them off I can turn the socket a full revolution without hitting the side of the bucket with the tool. Just makes install/removal easier.
I have tried installing with my impact driver but can't get them on tight enough with that and result to tightening the last bit by hand.
When I plow we have several feet of concrete right in front of the garage. So I remove the edge tamers and back drag the snow off of that onto the gravel drive. Then put the edge tamers back on and do the drive. Removal/install takes 2 minutes.
I really really like these if you cannot tell :)
/ Edge Tamer attachments #8
Yes with the constant supply of manure to deal with I leave them on 85% or more of the time.
Thanks for your input . Good information. I'm going to give em a try..
/ Edge Tamer attachments #10
I plan on purchasing a plow for next year, but it wasn't in the budget for this year. I didn't think the tamers would work for my gravel driveway, because it's not in the best shape. It has too high of a center, and a mix of different sized gravel that is well compacted in some areas, but very loose in others. I made my own "edge saver", mostly just hoping it would stop me from scraping too much gravel off the driveway. It has worked amazingly well. Works great on my gravel driveway, and even better on grass (frozen ground).
https://www.tractorbynet.com/forums...tractor-summer-no.html?highlight=#post5241197
/ Edge Tamer attachments #11
The beauty of the edge tamers is that they work well, and are only a 2 minute job to install/remove.
/ Edge Tamer attachments #12
And available commercially for those of us without the skills to fabricate something. The ease of install/remove is a huge plus.
/ Edge Tamer attachments #13
I get that. Was just showing the OP that there's other options out there, that can work just as well, or even better in certain situations. My solution comes on and off in about 5 minutes as well (it's just 5 bolts).
/ Edge Tamer attachments #14
Have uneven ground that I clear with bucket or blower. Edge tamers on bucket make it much easier, more relaxed, don't take as much attention to avoid scraping up ground. Have 3 on a 72" bucket. Have not tried without center one but will one of these days probably.
/ Edge Tamer attachments #15
I have them for my 67" bucket. I bought 3 so I have one to span the gap in the middle. They work exactly as advertised and I like them. In winter time, once our ground freezes up hard, it usually stays frozen until spring. So currently, mine are off again, as there's no need to worry about picking anything up with the edge yet. I use them in summer time too, if I'm moving dirt or gravel from a pile, I don't have to worry about digging in below grade level.
I also bought the Edge Extenders, and use them often in the summer time. They help with general tree/branch cleanup, and I can carry things like fence posts, or hang buckets from them. Most of the time in summer, if my Edge Tamers are on, it's to I can use the Extenders for something.
If I had to take my trash can down a long driveway, I'd also have the Trash Tamer too. But my trash service guy pulls in and turns around in my drive to pick up my can up by the house, so I haven't needed it.
Meant to add, about the only down side to having them on is you can't back drag with the bucket with them on, since they stick past the edge of the bucket a fair bit.
/ Edge Tamer attachments #16
Forgot to mention I have the edge extenders too. Some would say well why not get bucket forks and that is a fair question. The reason I like them is they are nowhere near as long as forks. Easy to put on and remove. So if you need to move around 4 wood posts or 50 t posts or something they are ideal.
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
TOWABLE HYD WOOD SPLITTER (A60430)
TOWABLE HYD WOOD...
