Echo Trimmer carburetor
/ Echo Trimmer carburetor #1
bmg88201
Platinum Member
Quitman, Ar
JD X300
I have a 12 year old SRM 230 Echo trimmer which has served me very well. Last year the carb got damaged after falling off the tailgate of my truck and I decided to get a cheap aftermarket carb off Amazon. It was like $22.00. I thought, wow what a deal. It starts up okay but I lost at least 1/3 if not more rpm and power. No way to adjust the carb that I could see. I struggled all last year with it and this year I bought a carb from Echo, it was I a little pricy but it runs like a beast again. Yeah I know, you get what you pay for. No complaints with Echo products, they make good commercial trimmers.
/ Echo Trimmer carburetor #2
I have several Echo products and am very happy with their quality. The 2 stroke tiller is 25 years old and still runs like a champ.
/ Echo Trimmer carburetor #3
Most of the newer stuff doesn't have adjustment needles... There should be a bigger diaphragm on the carb with a spring loaded needle on it, that's the fuel pressure regulator, if you pry the lever up a touch that might richen it up a little but could make idle rougher so gotta balance that...
/ Echo Trimmer carburetor #4
The echos usually have a high speed adjustment only. It's a small hole with a white or black plastic plug covering it and u use a 2mm flat screwdriver to turn it after u remove the plug. It's hit or miss with the aftermarket carbs. Sometimes they are better then the factory ones.
2016 Polaris Ranger 570 (A62613)
2016 Polaris...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
