ECHO SRM 225 String trimmer will not run
   / ECHO SRM 225 String trimmer will not run #1
Popsljc
Smithdale,Ms.
Case 580 CK
Trimmer had a problem of hard starting and not starting. First I checked the gas and fire. Had strong fire replaced the fuel filter, fuel tank vent and new fuel---still would not start . Disassemble carb blew out with carb cleaner, reassemble --still would not run. Carb was dry no fuel---Replaced carb with with new one made sure the fuel lines were in proper place---press primer bulb --fuel could be seen returning to tank through the yellow line. Choked it --pulled it still no fuel on plug---any suggestions ?????
THANKS
   / ECHO SRM 225 String trimmer will not run #2
Is it getting fuel to the carburetor bowl?
It is a Zama carb and it does not have a bowl. When you press the primer bulb you can see fuel going into the carb and then coming out of the return line.
Thanks Capt- Bought a new carb and still not running. The plug is dry.
   / ECHO SRM 225 String trimmer will not run #8
Will it fire with a wiff of starting fluid?
My Echo only gave me problems when the spark arrestor was carboned up... simply would not run.
Would not fire even with starting fluid---will pull the spark arrestor
   / ECHO SRM 225 String trimmer will not run #10
Sorry I should have paid more attention to what you originally wrote.
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2008 Polaris Sportsman 300 4x4 ATV (A51694)
2008 Polaris...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
2013 Ford F-350 (A53422)
2013 Ford F-350...
