ECHO SRM 225 String trimmer will not run
/ ECHO SRM 225 String trimmer will not run #1
Popsljc
Smithdale,Ms.
Case 580 CK
Trimmer had a problem of hard starting and not starting. First I checked the gas and fire. Had strong fire replaced the fuel filter, fuel tank vent and new fuel---still would not start . Disassemble carb blew out with carb cleaner, reassemble --still would not run. Carb was dry no fuel---Replaced carb with with new one made sure the fuel lines were in proper place---press primer bulb --fuel could be seen returning to tank through the yellow line. Choked it --pulled it still no fuel on plug---any suggestions ?????
THANKS
/ ECHO SRM 225 String trimmer will not run #2
Is it getting fuel to the carburetor bowl?
It is a Zama carb and it does not have a bowl. When you press the primer bulb you can see fuel going into the carb and then coming out of the return line.
Thanks Capt- Bought a new carb and still not running. The plug is dry.
/ ECHO SRM 225 String trimmer will not run #8
Will it fire with a wiff of starting fluid?
My Echo only gave me problems when the spark arrestor was carboned up... simply would not run.
Would not fire even with starting fluid---will pull the spark arrestor
Just want to thank everyone for the suggestions. Today I removed the flame arrestor and it started, but ran pretty bad. So I removed the muffler too. Guess what it ran perfectly without anything connected to the exhaust port. So I went back into my stash and found a muffler and arrestor from another unit, installed it and the thing runs perfect. THANKS AGAIN FOR YOUR SUGGESTIONS
/ ECHO SRM 225 String trimmer will not run #12
I'm so glad to hear you had success!
Many would just give up... good going.
/ ECHO SRM 225 String trimmer will not run #13
My Echo trimmer was a PITA to start at the end of 2016 and I figured I would probably junk it in 2017, but I got by with it for over half of 2017. Finally, it wouldn't start at all and its borrowed time ran out.
/ ECHO SRM 225 String trimmer will not run #14
Those spark arrestors on 2 strokes WILL carbon up & not allow adequate exhaust flow.. No air out=no air in..
I had a garden tiller that did the exact same thing..
Pulled it all apart, fixed the carb.. reassembled.. nothing.. hit it w/ ether.. cough, cough. spit, spit.. wouldn't rev up..
bought a new carb, put it on, same thing.. I was just about ready to throw it in the woods, literally, when I decided to TRY one more thing..
I saw a "pull tab" on the exhaust muffler.. I pulled it out[mesh screen] & pulled the start cord.. it fired up on the 1st pull.!!!
Give it a try..
JOHN DEERE LAWN MOWER (A65054)
JOHN DEERE LAWN...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
Harrell 3pt 4 Row Stalk Puller (A64127)
Harrell 3pt 4 Row...
