Echo 2620 or 2620T?
/ Echo 2620 or 2620T? #1
nancyk
east Tennessee
Deere 5055e 2015, Ferris IS2000z 2007
I have narrowed down the choice of a new string trimmer to possibly the Echo 2620. Does anyone have direct experience with both models, the 2620 and the 2620T? The T specs say it has more torque, though both have the same 25.4 cc's.
The person using this weedeater is not tall, so do not want to get a unit that is too heavy or long.
If I can find one locally, I will probably go with the 2620T.
/ Echo 2620 or 2620T? #2
Mines a PAS266 which is the older engine version of the 2620, same size engine at 25.4cc. I know yours's isn't the powerhead with accessories, a trimmer only.
If the higher torque uses the same engine it'd have to be the head gearing (I'd think) so it probably has a slower rotation to give you higher torque.
The trimmer head on mine is a higher toque and it works great, more than enough power to use string or a blade.
I'm 5'-9" and it's just the right length for me but it's not light
/ Echo 2620 or 2620T? #3
I have the echo straight shaft with the bicycle handlebars and the over the shoulder harness. I bought the one with the metal drive shaft, not the spring wound one. it replaced a Stihl FS66 straight shaft I've had for decades. Quite happy with it and I usually have the scratcher blade on it, not string though the Stihl tri-cut head fits the Echo as well. Think mine is 34cc, I think.
"slower rotation to give you higher torque" Yes, that is correct.
213324 (A64279)
213324 (A64279)
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2014 FREIGHTLINER CORONADO 122 SD (A67714)
2014 FREIGHTLINER...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2013 CATERPILLAR 259B3 SKID STEER (A65056)
2013 CATERPILLAR...
