Easy way to uncross bush hog blades
   / Easy way to uncross bush hog blades #11
I just run it very slow and drop the deck a few times always have come loose.
   / Easy way to uncross bush hog blades #12
I had the same thing happen--brush hog blades got crossed when the tractor shut down trying to start the mower. I uncrossed mine with a sledge hammer pretty easily. Hit one blade near its end.
Mine would not budge with small crowbar and hammer. Finally removed tail wheel and loosened one bolt a couple turns. That released the tension. Tightened and torqued the blade bolt back and replaced tail wheel.
Thought about revving to 3,000 rpm and popping the PTO button. The vibration could be terrific if they didn't pop out. Don't think they would have because centrifugal force to cause them to would be less with them tucked back together the way they were.
Ralph
202482 (A54757)
202482 (A54757)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
