Oil & Fuel Easy way to transfer hydraulic fluid from 5 gal buckets?
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #1
bitternut
Western NY
2000 John Deere 5210 mfwd, John Deere 350C Crawler
My 5210 is needing its 1200 hour hydraulic oil change. Since this will require two 5 gal pails of HY-GARD plus another gallon or so is there an easy way to do this. I don't relish the thought of trying to pour it in from a 5 gallon bucket. Would a siphon hose work pretty easy? I have one of those cheap siphon tubes with a small bellows on it for transferring kerosene and thought that might work OK. Anyone have any ideas or suggestions?
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #2
Lay the 5 gallon bucket on its side with the spigot at the top. Open the spigot and as you slowly roll the bucket to one side, have a one gallon container under the spigot. I use an old antifreeze jug that's been rinsed out. You can easily control the outflow by rolling the bucket. Not the fastest way to pour, but one of the easiest.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #3
A siphon will work, but will be pretty darn slow, I would think.
Do you know about rolling a 5 gallon pail on its side and pouring from the high side into a smaller, clean container? A lot of people do not know this trick. I posted a link to a video about it earlier this year and got a lot of WOW comments, as many folks don't know this. I didn't until someone showed me, so here goes... hope it helps you out. Works with any liquid in a 5 gallon bucket with spout.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #4
Beat me by 1 minute! :laughing:
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #5
I really like these pumps for transferring heavy fluids. Kind of pricey but they pump 8 oz per stroke and make fast work of moving a lot of oil. They are advertised for tire sealant but also do well with oil.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #6
I just did my hydraulic oil a few weeks ago, 17 gallons, I have a hand pump that goes into the spout on five gallon buckets, works really nice. This one is from harbor freight and looks just like the one I bought from a local farm store.
5 Gallon Oil Pump
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #7
COme on ....surely this is not a serious question. We've had tractors in the past that you added 5 gallon every morning. The bucket doesn't weigh 150# . a funnel and start with the spout on top.
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #8
Tell that to someone with arthritis, back problems, etc.... Lifting a 36# bucket of oil up high enough to pour into a funnel and keep it there while it empties isn't easy for a lot of people. ;)
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #9
It was easy when I was 25. Now that I'm in my 60's....
   / Easy way to transfer hydraulic fluid from 5 gal buckets? #10
Work smarter, not harder..... :laughing:
At my last job, I had to fill chemical film processors from 5 gallon buckets at about 4.5' off the ground. Two buckets twice a week. I was able to lift them, but several of my vertically challenged coworkers (I had a few that were under 5' tall) couldn't get them up that high and hold them while they poured. They physically didn't have the body mass to counterweight that pail out a couple feet in front of them.
2018 Ford F-350 Flatbed Truck (A55973)
2018 Ford F-350...
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
Portable Restroom (A54865)
Portable Restroom...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
