EASY way to keep the tarctor fueled?
   / EASY way to keep the tarctor fueled? #21
I have a JD 3320 without a cab, and this continues to be a huge problem for me too. Here is what I'm thinking about doing:
1. Get one of these 15 gallon Blitz Fuel Stations for $79.99:
Blitz 15-Gallon Professional Fuel Station&#153, Model# 11055 |Gas + Oil Cans | Northern Tool + Equipment
2. Store it in my garage - my wife doesn't want stored fuel inside the horse barn where the tractor is stored - Makes sense.
3. Buy diesel fuel in the yellow plastic 5 gallon Blitz cans.
4. Put a somewhat empty Blitz Fuel Station inside the front end loader.
5. With the loader still down on the ground and the tractor off, pour fuel from the 5 gallon can(s) to the Fuel Station tank.
6. Make sure the Fuel Station's hose & nozzel are hanging from the side of the FEL. Start the tractor and raise the Fuel Station above the tractor's fuel tank cap.
7. Turn off the tractor with the FEL still raised.
6. Open the tractor's fuel tank cap and fill the tank using the Fuel Station's hose and metal nozzle. I'll have to watch carefully so that I don't overfill, but the nozzel shouldn't weight too much.
7. Once filled, replace the tractor fuel cap, start the tractor, lower the FEL, and return the now much lighter Fuel Station to the garage.
What do you think? Is this dangerous? Do you think the Fuel Station hose will reach?
I might put a shelf just inside the garage door that the Fuel Station can sit on and use a ladder to fill the fuel station, but our garage has a long overhand and I don't think the ROPS will let me get that close to the Fuel Station.
I'm not wild about the idea of using the tractor bucket this way. Just violates my background in safety management . . .
Jim G
   / EASY way to keep the tarctor fueled? #23
Jim G
& I'm not wild about putting gasoline and other fuel in a garage house or other building.
   / EASY way to keep the tarctor fueled? #24
Tractor supply has 110 volt or 12 volt fuel pumps. My right elbow is shot, so I cant hold a fuel can more than a few minutes. I purchased a 110 volt pump, fuel filter and a bung adapter from tractor supply. My brother-n-law gave me a clean 55 gallon plastic drum that will hold the diesel fuel for my tractor. After putting this setup together and using it all summer and through the fall. I am so glad I went this route. It takes me less than a minute to fill my tractor up. The pump I purchased, puts out 15 gpm. The filter is 5 or 10 microns and I dont have to weary about trash in my tractor tank. I cant find a link, but you will have to get the fittings so that you can hook the fuel filter up to the pump. Yes, this is an expensive setup but who said owning a tractor was going to be cheap. Check out the links if you guys are interested.
110-VOLT ELECTRIC GEAR PUMP $295.35
Tractor Supply Company - 110-VOLT ELECTRIC GEAR PUMP
FUEL FILTER $19.08
Tractor Supply Company - FUEL FILTER
BUNG ADAPTER $15.26
Tractor Supply Company - BUNG ADAPTER
   / EASY way to keep the tarctor fueled? #25
How do you fill the drum?
Do you use Red Diesel?
FUEL FILTER $19.08
BUNG ADAPTER $15.26
   / EASY way to keep the tarctor fueled? #27
Does RED diesel weigh more or less than clear diesel?:confused:
   / EASY way to keep the tarctor fueled? #28
Not sure but me thinks a pound of red diesel weighs about the same as a pound of clear diesel.;)
But how much does a gallon of red diesel weigh compared to a gallon of clear diesel?:)
Anybody know how much the RED Dye weighs per pound?
   / EASY way to keep the tarctor fueled? #29
My tractor has a 18LA FEL which will pick that 55 gal drum with no problems. I just load it on the trailor and take it down to the fuel depot and fill it up with Farm diesel ($1.89). Bring it home and unload it with the tractor. Right now, It's setting on a pallet in my shop. This weekend I'll be building a dolly for it so that I can roll it around the shop and also so that I can load it onto the trailor with the pallet forks. Building this dolly with wheels and loading brackets will make it even more fun for tractoring. I have better things to do than stand around holding a 5 gal can of fuel trying to fill the tank full of fuel. BTW....I have no idea what diesel weighs per pound. My tractor will pick up a 55 gallon drum full of diesel and that is all I care about.
   / EASY way to keep the tarctor fueled? #30
I was thinking about getting a transfer tank in the 30-50 gal range and setting it up behind the shop on a stand to either gravity feed or pump with a low voltage pump outfit. The idea would be to use the FEL to transfer the tank from my pickup (for filling runs) and the stand. At roughly 8 pounds/gallon the high end weigh is 400lbs + tank weight. Should be a non-issue for both truck and FEL (300CX). The only problem I'm having right now is either some feature on the tank or other type of lifting fixture that can support a loaded tank weight.
48" Farm Jack (A53316)
2001 International 4700 Aircraft Fuel Truck (A55788)
2001 International...
BUYERS PREMIUM & PAYMENT TERMS (A56138)
BUYERS PREMIUM &...
2019 Cat D6N LGP Dozer (RIDE AND DRIVE) (A50775)
2019 Cat D6N LGP...
2016 Kenworth K370 30FT Box Truck (A55788)
2016 Kenworth K370...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
