Easy way to drill big holes (step bits)
   / Easy way to drill big holes (step bits) #11
I bought my first Unibit in 1985 or so. I now have a bunch, different sizes. They are great.
   / Easy way to drill big holes (step bits) #12
You should try it Bird, they are pretty handy, particularly on sheet metal panels and boxes(metal thinner than the height of each step on the bit).
I don't think I have ever seen a 2 fluted one... Hole saws these days are also pretty impressive in their performance but can be a little more difficult to manage in a hand held drill.
   / Easy way to drill big holes (step bits) #13
bx24 said:
Skyco ... I noticed the two flute comment as well. The ones I have used only have 1.
I would encourage anyone who is skeptical about these (like I was) to try them
Thats why I didnt buy em. The 2 flute ones chatter. Ill have to get some of the cheap ones to spell my Uni-Bits on grungy stuff.
larry
I agree with Ron Bird, you should try it. Like I mentioned, I was skeptical and so long as traditional methods worked, I was happy enough. When I got into a situation where I did not have the clearance to use a long 1/2 drill, I gave the flute a try.
As mentioned before, thin metals worked well (that I would have expected), but I was VERY impressed with the thicker plates given that I was not using anything more powerful than a cordless drill.
Give it a shot!
   / Easy way to drill big holes (step bits) #15
One word of caution I forgot to mention in my first post. Be cautious in sheet metal, it can catch and buckle/warp the metal. The first Unibit I got I purchased to drill holes in heavy OTR trucks to run CB antenna wires and heated mirror wires. The bit caught one day and it buckled the door sheet metal. :( Luckily I was able to pop it back out from the backside with a little help from a rubber mallet and bodymans bean bag. Thank God I got it out because it was a brand new truck that hadn't been delivered yet. :)
   / Easy way to drill big holes (step bits) #16
I'm glad this was posted. I have been considering buying a set for some time and was recently at a HF store in St. Louis and they were on sale. I talked myself out of them for fear that they would quickly dull. Looks like I'll get some after all, Thanks.
When I was doing my loader last year I was looking for a way to drill the holes for the pins, bolts, etc. in 1/4"-1/2" sheet and was trolling Ebay and saw a set of B&D bimetal hole saws that were really cheap. I had always assumed hole saws would only be good for thin sheet metal but out of necessity decided to give them a try anyway. WOW, I couldn't believe how good they work. I have since drilled countless holes with them and have been very impressed. I finally wore out one of the Black and Decker saws and went to my local Rural King and bought a Milwaukee brand to replace it. I bought just the "saw" and used it with the original B&D bit (that has yet needed to be sharpened) and all is good still yet!
   / Easy way to drill big holes (step bits) #17
Bx24,
Good you brought this up. These drills are so handy if you are just tring to get a bigger hole. I have used them on material where the steps are smaller than than material. In other words I want a 3/4" hole but the 7/8" step will start to cut on top before the 3/4" is completely through. JUST stop in time before the 7/8" starts to cut. Use a rat tail file to clean the small rim left.
I got mine when the factory I worked at closed to move to (name the spot)and....every employee started grabing tools. I never thought it would be so handy. Carefull though, they can grab.
One last coment; never use a cordless tool where a corded drill can do the job with ease. Drilling plate steel can be done via cordless, but with much ware a tear!
Glad for your discouvery...Patrick T.
   / Easy way to drill big holes (step bits) #18
Thanks for the reminder. I bought a set from HF a year ago and never tried them. I was skeptical which is silly after paying for them. LOL
I will definately give them a try next time I am drilling a hole in something thin.
   / Easy way to drill big holes (step bits) #19
Bird said:
I have a #1 Unibit (1/8" to 1/2") that I bought on the advice of my brother 6 or 8 years ago. It's still in the package; never been opened or used.:D
Hi Bird, put it in a Yardsale, I'll buy it.
I just bought my first set this year and can't believe I've been using 3 bits to drill one hole all these years. I also use mine on the drill press. I'll never be without them again.
Terry
   / Easy way to drill big holes (step bits) #20
I used my unitbit and 18volt cordless to drill the two 1/2" holes in my fel for the toothbar.
Worked great.
Once you get past the $35-$40 initial cost, they're like most tools..worth it.
19088 (A55758)
19088 (A55758)
MASSAGE CHAIR (A58214)
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
