Easy to get the EX3200 stuck
   / Easy to get the EX3200 stuck #11
Just my two cents, but the operators manual for the EX3200 specifically said NOT to install front tire chains as it will hit and damage the tractor. I would be more inclined to stick with some weight on the front bumper.
   / Easy to get the EX3200 stuck #12
...and whenever possible fill the FEL with dirt, logs, etc., engage rear differential (foot pedal), and engage 4WD to front wheels to increase traction when traversing loose or slippery surfaces.
   / Easy to get the EX3200 stuck #13
As I said the clearances with the chains are tight, but with careful installation they do work on my 6284 (the manual makes no reference to chains). I would recommend that if you purchase chains be sure that you can return them if they won't work. Remember also that you can expand or reduce the diameter of the side chains which was a big factor on my tractor in providing the needed clearance when installing them.
I keep a careful eye on the chains to be sure that they don't shift to where they can potentially cause damage, but after carefully and securely installing them they never moved on me. I limit their use to snow, ice, and soft ground. Given the rough ride the chains provide they certainly are not subject to pavement or high operating speeds.
Short of purchasing an entire new set of wheels and AG tires for all four corners the chains made the difference between having a very useful tractor for processing and hauling firewood in the woods in deep snow vs a tractor that is stuck in the barn until spring.
In some cases I agree that you can fill the FEL to add weight but I wouldn't recommend it for extended use. The additional loading placed on the FEL frame and the chassis by suspending weight this way is substantial. Front suitcase weights are the best way to add weight.
Belated thanks for all the info. I was away all weekend to a AAA baseball game. Six hours on the road and didn't see 1 Cub Cadet dealer. :laughing:
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 International 4400 Cab & Chassis (A47384)
2015 International...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
CATERPILLAR 259D3...
