Easy, no spill oil change aids
   / Easy, no spill oil change aids #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
With the mower deck installed on my 4210, there is very little room under the engine to fit any decent size oil pan, only a very shallow and small capacity pan would fit...nothing that would hold a gallon of old oil. A long section of PVC rain gutter with an end cap cemented on works great as a draining trough, and a second section notched out to fit under the side-mounted oil filter on the Yanmar keeps old oil from dripping down when I remove the filter, instead it flows into the drain pan.
   / Easy, no spill oil change aids #3
Those look like great ideas.. I Plan to steal that for my little JD mower. thanks
James K0UA
   / Easy, no spill oil change aids #4
I've used a piece of folded cardboard before. Made it into a v and the oil runs down it into a pan.
That would work well as long as the oil didn't seep thru the cardboard. I should have mentioned in the original post that it's a good idea to get the gutter section up as far as possible toward the drain plug so the initial gush of oil doesn't splash over the sides.
   / Easy, no spill oil change aids #8
Alright so I see the video.. and I am convinced that this is the best thing since sliced bread, and then track one down, to buy it and holy cow!. they want 25 bucks for one..I was prepared to maybe pay 10 bucks, but 25? I guess I am just a cheapskate.:irked:
James K0UA
   / Easy, no spill oil change aids #9
Form A funnel is awesome according to guys I talked to. Im getting one whenever I get to a retailer who has one. Yes it's expensive. Its also made in USA. Im sure they could make it in china for 1/2 but I for one am more than happy to support a manufacturer who is committed to North American manufacturing.
   / Easy, no spill oil change aids #10
I'm a cheapskate, but I bought one. It actually IS the best thing since sliced bread.
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A52706)
2019 CATERPILLAR...
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
