Easy, low buck, exhaust mod to eliminate soot on FEL
   / Easy, low buck, exhaust mod to eliminate soot on FEL
Ah your a good man to be able to come back and give an honest review of the exhaust. You've earned my respect for what ever that's worth.:confused2:
In the mean time IF you decide to go the way I did and you need some help just pm me. Hope your enjoying your very nice tractor. :)
Thanks. That's what is forum is for, is to share knowledge. Good and bad. :confused2: I did also have a concern about the exhaust kicking up too much vegetation debris from brush hogging, disc mowing, hay baling etc, because I would have to stop once about 3/4 through the day to blow or wash out my radiator, a/c condenser, and hydro cooler. The turned down exhaust may still contribute, but I had a buddy have the same problem with his JD 4720 with factory exhaust. Maybe the stack would help. Or maybe they are just too low to the ground compared to larger utility and ag tractors. I know I don't have any of the same problems with my buddies JD 6300 or 7410 when I'm mowing, raking or baling hay. They will go for 20-30hrs without having to clean them out. On another note. Noticed under the 4720 hood that JD had an intercooler. I know it makes a big difference on a vehicle. Wonder why my Kubota L5740 doesn't have one. Wonder if I could make some room up front, do a little plumbing and install one. Would it be a noticeable difference or just on a dyno. Hmmmmmmmmm??? :confused: Course I've never really needed any more power, now that I think about it. Might be more fuel efficient though.
   / Easy, low buck, exhaust mod to eliminate soot on FEL #42
If you could find a nice spot to build a battery box you could move the battery out of the way and you would have all sorts of room for an intercooler.
Yeah, battery, horn headlight buckets etc. It would be a fun project. Maybe this winter. Right now I don't have much R&D and fabrication time. If I can come up with an intercooler between now and then, I'll be sure to post the project. Oh wait. Maybe not. Just realized that I'm pretty sure that could void my warranty. Only 150hrs right now. Might better wait a little while.
UNUSED FUTURE FT13CJ EXCAVATOR (A57192)
UNUSED FUTURE...
PALLET OF ALUMINUM PARTS (A57192)
PALLET OF ALUMINUM...
John Deere 997 Z-Trak 60in Zero Turn Commercial Mower (A55851)
John Deere 997...
2005 Sterling Acterra Tender Truck (A57024)
2005 Sterling...
INGERSOLL RAND SD-100D SMOOTH DRUM ROLLER (A52707)
INGERSOLL RAND...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
