easy change system
/ easy change system #1
tarrak
Manitoba
L3400
I've seen the" easy change system" advertised on the home page and would like to know from users what they think about it.
Thanks,
Geert
/ easy change system #2
Best thing I ever bought for myself.
The local Catholic school principle also sent home a thank you letter with my daughter shortly after I installed the easy change. Seems that my voice echos over the hills around here and when I get frustrated trying to put on a heavy implement the local school kids learn some new words . . . or at least learn new ways to string together words they aready know. Well all that swearing stopped when I installed Pat's system.
Then there was the local emergency room staff who sent a my wife a sympathy card after I installed Pat's easy change. Apparently they thought I must have been crushed and died under an implement because I hadn't been into to get stitches, a cast or tetnus shots in a few weeks.
/ easy change system #3
Pat's Easy Change has reduuced my cursing quite a bit.
It's a heck of a lot easier to hook up the rear blade or rotary cutter.
I never had much problem with the finishing mower (4 caster wheels), but the rotary cutter was always a 20 minute operation levering it around to mate with the lower links.
Now...maybe a minute or two and a lot less agravation.
I reccomend Pat's Easy Change 100%!
Now, that may, or may not require a new PTO shaft...depending on how much overlap you have in the shafts.
/ easy change system #4
Should be called "Pat's stress, blood pressure and back pain reliever" /forums/images/graemlins/grin.gif
/ easy change system #5
Tarrak,
I liked it a lot on the BX 2200. The lift arms on that machine were a little short, and the Pat's system gave them some much needed reach. I do not like it on the B7610 because it seems to me that the added length makes the implements stick out TOO far. That's probably more a perception issue than anything else.
Best regards.
Killer B
/ easy change system #6
It should be a "required" purchase for almost anyone who uses more than one implement and even for someone with only one that gets removed once in awhile! I'm SO pleased with it that I'm only sorry it wasn't available years earlier.
BTW, I like it, too... /forums/images/graemlins/grin.gif
/ easy change system #7
I'd bet that everyone on site that has the easy change will agree: The only way I'd be without the Easy Change is if you PRY IT FROM MY COLD DEAD FINGERS. /forums/images/graemlins/shocked.gif
/ easy change system #8
I use to dread (see above posts relating to profanity/injuries)removing/attaching my 1 and only rear implement before I got Pat's system so it would stay on the tractor all the time. This reduced the utility of the tractor somewhat.
After Pat's, it is on and off all the time. 1-2 minutes to hook/unhook max. No injuries. No profanity, so I might get into the pearly gates yet. Other than the tractor iteself, it is the best money that I have spent.
At one point I was looking for a quick hitch. I got tired of waiting for a particular hitch to be produced. Looking back, this is a better (and cheaper) system because it will fit more implements without having to resort to welding adjustments to complete the implement-tractor attachment.
Thanks to all of you who responded. It's clear to me that this is a must have and that the item seems to be better and simpler than any other system on the market.
/ easy change system #10
I have a tad less than 4 inches of streight arm. can anybody tell me if that will make it.
/ easy change system #11
I've never seen this quick hitch up close, so I just wondered what kept the arms from sliding off the end of the pins. The pictures in the advertising don't show anything that will hold them together
/ easy change system #12
I called the company and they said it would work with the 3 inches of straight arm length that my tractor has. Yours should be fine. Ben
/ easy change system #13
</font><font color="blue" class="small">( I've never seen this quick hitch up close, so I just wondered what kept the arms from sliding off the end of the pins. The pictures in the advertising don't show anything that will hold them together )</font>
The same pin that keeps the 3ph arms from falling off the attachment.
/ easy change system #14
rope1
Here's what one looks like close up, maybe you can tell something by the pic.
/ easy change system #16
I have the system on my 23, and with the exception of all the adjusting screws and the ubolts, mine is the same as everyone elses. I have found that these items may not be needed as much as it seems. I have only the pins going thru the sockets in my lift arms, now everything fits without adjusting anything. Your lift arms are not at the same angle for a 48" tiller as they are for your other implements and with all the set screws I found that they were not "square" all the time, dont have that prob now.
Pats is great, especially on the CUTS and SCUTS.
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A59914)
2008 FORD E- 350...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
