Easiest way to remove 422 battery
   / Easiest way to remove 422 battery #1
bullitt
Pittsburgh PA
pt422
The battery in the 422 is shot. A casual inspection does not reveal an easy way to remove the battery.
Unfortunately, the battery will require replacement in advance of the engine upgrade.
Any suggestions?
bullitt
   / Easiest way to remove 422 battery #3
I had to remove the muffler to change my battery. I have one of the "new" welded PT-made mufflers though (which may be larger than the Kohler muffler).
   / Easiest way to remove 422 battery #4
Bullit,
The bad news, you do have to remove the muffler. The good news, pretty easy to remove the muffler. Is your battery still under warranty. Curious that it failed so quick. Let us know what you end up with for a battery.
Duane
2000 Chevrolet C2500 Ext. Cab Pickup Truck (A55852)
2000 Chevrolet...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
2005 Peterbilt 387 with Wet Kit (A57024)
2005 Peterbilt 387...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
