Easiest way to get oil out of a gearbox??
   / Easiest way to get oil out of a gearbox?? #31
That contraption does, indeed, work. :)
But only if you're near a power supply. :rolleyes:
   / Easiest way to get oil out of a gearbox?? #32
You guys never made a "suck bucket"?? Take a wet/dry vac.. hook the main hose on a 5 gal bucket spout.. now get a smaller hose, 5/16" or smaller depending on what kinda room you have in the sucking area.. poke a small hole in the lid of the 5 gal bucket & insert the smaller hose..
The vaccum from the wet/dry vac will cause a vaccum in the 5 gal bucket, therefore sucking at the end of the 5/16' hose..
ALL the liquid ends up in the 5 gal bucket & not in the wet/dry vac....
Its good for all sorts of things.. Try it, it works..
Great info; I think next time I have to change my hydro fluid I'll do it that way. :thumbsup:
   / Easiest way to get oil out of a gearbox?? #34
I usually wrap some hay twine and/or barbed wire around my output shaft, thereby allowing the bottom seal to become a drain.
That is the “Never Change Oil” just add method.
1997 Chevrolet C3500 Auto Crane Service Truck (A55852)
1997 Chevrolet...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2025 JOHN DEERE XUV 825M S4 UTV (A57192)
2025 JOHN DEERE...
2019 JOHN DEERE 17G EXCAVATOR (A52707)
2019 JOHN DEERE...
UNUSED FUTURE FR70 HYD FLAT RIPPER (A57193)
UNUSED FUTURE FR70...
2022 BOBCAT S770 SKID STEER (A52707)
2022 BOBCAT S770...
