Easiest way to drive a belt drive tiller on a Satoh S370D ?
   / Easiest way to drive a belt drive tiller on a Satoh S370D ? #1
sourwood
North Carolina
Farmtrac 665DTC, Zetor 7711, Long 460, Long 310, Satoh S370D, Iseki 4100F, Case 380CK, John Deere 420C
I have a John Deere belt drive tiller, a 30" model. I would like to be able to use it with my 4x4 S370.
I have thought about adding two routing/idler pulleys- like on a belt drive belly mower that uses a pulley driven on the rear pto- and driving it off my rear pto.
The other thought was to add the "engine pto"- ie the pulley that drives off your crank, but that will still require a set of idlers.
I have the parts ordered for my PTO reverser build. Once I get my gear set, bearings, and a replacement boring head, I will be finishing my PTO reverser, and then I need to get this tiller usable.
The box I've been working on will end up bolting up like an OEM Box, and will produce a near perfect 539.xx rpm PTO in the clockwise direction.
I proof of concepted it with a set of used gears, and it ran great. Someone walked off with the gears, my boring head, and a Snap On FM70, so that has stalled things.
When the new gears and head arrive, it is off to the races, but I'm wondering if anyone else has adapted belt drive implements, even the odd belly mower to a Satoh.
I love these tractors.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2018 John Deere 325G (A47477)
2018 John Deere...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
