EarthForce EF-5 enhancements
   / EarthForce EF-5 enhancements #11
If you need a source for LED lighting, check www.whelen.com -- they produce emergency lighting / industrial lighting for most applications. They were also one of the first companies to market LED lighting
for emergency vehicle / construction use. We have started adding LED's to some of our patrol cars and they really do seem brighter in sunlight -- not quite the brilliance you get at night with strobes, but for your use, definitely the best choice.
   / EarthForce EF-5 enhancements #12
Now, I might be off a little on the picture, but just where do you put the tiller on this Earth Force vehicle?
<=======/w3tcompact/icons/laugh.gif
Keep the greasy side down.
Mike
Last Tuesday, I went to see Jason @ Folcomer Equipment and picked up a couple of the items I bought from him. One of them that's applicable to any tractor with a FEL is the FFC bolt-on edge. I thought they looked quite interesting on their web site, so I went ahead and sprang for one for the EF-5's 74" 4-in-1 bucket and another for the 78" large capacity bucket I had built. They're about $400 for a 72" one, delivered.
When I picked them up, I was quite surprised - they're much heavier duty than I expected them to be; well, more aggressive might be the better way to put it. Anyway, here's the web page I found them on: http://www.ffcattachments.com/cdrom/buckets/BK10.htm. I got the wide tooth model. Don't be fooled by the pictures - those teeth are not nearly as small as they appear: they're 4 3/4" wide at the bar and 5 1/2" long. Rather than coming to a sharp point, they're a bit rounded with respect to width and tapered to an edge with respect to thickness. They seem to be made of extremely high quality steel. I'm anxious to try them. It's already pretty clear that regular teeth will no longer be needed on the bucket, using this edge. Plus, an advantage of this style of edge vs. traditional teeth is that the bucket can still be used for smoothing by just flattening out the bucket. I'll see how well that works, too, when I get to use it, but it seems a viable concept, anyway. This isn't of too much concern when you've got a 4-in-1, because you can always open the bucket to get a flat edge, but the ability to have a lot more teeth with this edge may be very useful for breaking up clods, cleaning up debris, etc.
For smaller tractors, I'd strongly suggest considering the narrow-tooth model, though - as I said, the teeth on the wide-tooth model are serious. I'll post a picture of it with a quarter laying on the tip of a tooth to give a better perspective of the size soon.
MarkC
Re: Pic of bolt-on tooth edge
Here's the promised picture of the FFC bolt on edge, wide-tooth style. The coin laying on the tooth is a quarter.
MarkC
Re: Pic of tie down chains
Since the EF-5 has 4 tie-down points, it's better to use 4 chains to hold it on the trailer, rather than run 2 long ones from one side to the other, the way I did it with the Kubota. I wanted to make up 4 separate chains with a big hook on one end that would clip in the tie down hole without any possibility of falling out and a grab hook on the other end to hook onto my trailer tie-down points. Additionally, I wanted to use a spring binder, so it could automatically take up the slack when the EF-5 bounces on its tires - especially important when I get around to putting the Michelins on it.
The only thing I could find in the way of chain, hooks and binders locally was Chinese junk (again, my usual disclaimer: not implying that everything made in China is, but this stuff was). So, I called up the guys at Labonville since they've always come through for me before. Attached is a picture of what they sent me, after I put the hooks on the chains. They cut the chains to length without charging me extra. It's all G80 or G100 stuff, made in the US by CM, or in Austria by Pewag (that's right, for you long-timers - Pewag of square link choker chain fame). (The coin laying in the slip hook is the aforementioned quarter...) Notice the really heavy duty alloy guards on the slip hooks, too. Even the binders are made in the US.
Now, if I just had an EF-5 I could bind down, I'd have what I need to do it... /w3tcompact/icons/smile.gif
MarkC
   / EarthForce EF-5 enhancements #16
Mark, that really is going to be an impressive piece of equipment (if you ever get it and get it all customized)./w3tcompact/icons/laugh.gif
Bird - If it's as impressive as your sig, I'll be fat, dumb and happy. (Two down, one to go... /w3tcompact/icons/laugh.gif)
MarkC
   / EarthForce EF-5 enhancements #18
Yeah, Mark, ain't that impressive; wish I could take credit for it./w3tcompact/icons/laugh.gif
Bird - I know what you mean - literally...
MarkC
   / EarthForce EF-5 enhancements #20
Mark\'s lucky quarter...
<font color=blue>… The coin laying on the tooth is a quarter…The coin laying in the slip hook is the aforementioned quarter...</font color=blue>
You’re sure getting a lot of mileage outta that quarter Mark…
When the Earthforce comes… take a picture again…with that quarter… /w3tcompact/icons/tongue.gif {and maybe JB Weld it to the undercarriage…}
Kohler Diesel Pull Behind Generator (A55272)
Kohler Diesel Pull...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLFCART (A58375)
UNUSED SDLANCH...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
600 Gallon Water Tank (A57149)
600 Gallon Water...
2014 Toro Greensmaster 3150-Q Commercial Reel Mower (A56857)
2014 Toro...
