earthforce backhoes
/ earthforce backhoes #1
coolaid456
orangeburg s.c.
2000 bobcat backhoe
good guys and girls i have a earthforce b 250 backhoe it moves good when the hydraulic is cold but as soon as it warms up i get no movement. change filter put in new pump .can anyone tell me if they sell oem parts for this tractor i like my little tractor.but if it do not run the boss said she got to go need help bad
/ earthforce backhoes #2
I think you need a flow and pressure check to see if the pump is performing at specs or close to specs.
Fluid does thin out as it gets warm.
You might check to see if you are using the correct fluid for your area.
hey thanks j.j. i change fluid and found out i need a hydraulic motor am try to see if anyone else beside bobcat sell these parts. any info would be thankful
hey dennis did he find out what was the problem need help bad.
/ earthforce backhoes #6
coolaid456
Did you mean pump or motor. If motor, what is it for.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A59230)
2007 Mitsubishi...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
