Earth and turf plow for Kubota b7500
   / Earth and turf plow for Kubota b7500 #1
dmonroy
Enosburg, VT
Kubota b7500
I am considering purchasing an Earth and Turf plow model 1sc600 for a Kubota. Does anyone own one and what is your experience with it? It clamps on to the bucket.
Thanks,
Debra
   / Earth and turf plow for Kubota b7500 #2
Debra, welcome to TractorbyNet. I have not used the plow you mentioned. I have a B7500 and would never again use anything that clamps on my bucket. I used a friend's homemade forks and that ended up putting a couple of nice dents in the bottom of my bucket. Not sure exactly how this blade connects to the bucket but it might cause a problem under adverse conditions. I do use a snow plow that connects directly on my loader arms. I adapted the plow myself but there are manufacturers out there, like Curtis, that sell plow blades that mount directly to the loader, no bucket. You will have better control with the blade closer to the tractor. The front end of our B7500s don't weigh much and this becomes a problem when the blade is angled trying to push a good snow load. A blade in front of the bucket will just add to the leverage that wants to move the front tires off course. It also increases your turning radius which may or may not be a problem for you. I have chains on front and back but that doesn't really help this situation.
   / Earth and turf plow for Kubota b7500 #3
Tractors are fundamentally PULLING machines.
If you attempt to PUSH very hard with the FEL you will either bend the FEL or lose traction on the rear wheels.
FELs are primarily engineered to LIFT not push.
Thank you. After reading your note I decided against purchasing the plow. The Youtube video was impressive but I still had doubts. Thanks for the advice.
Thanks, your reply was helpful. I've called the dealer and asked for information on a plow that attaches to the loaders.
   / Earth and turf plow for Kubota b7500 #6
What are your intended uses for a plow? Opening land?
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
1996 16ft Triple Crown Trailer (A51572)
1996 16ft Triple...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
