Early 70's 310 3 cyl diesel runs for 10-20 seconds and dies.
   / Early 70's 310 3 cyl diesel runs for 10-20 seconds and dies. #1
RG307
John Deere 310 Loader/Backhoe
Just replaced the lift pump. Bled system. Started and ran good for about 30 seconds and died like it lost prime. Waited about 5 minutes, restarted and ran about 10-20 seconds. It will restart every time, but won't stay running. Getting fuel to the injection pump. Pulled inlet screen on inj pump and cleaned. Still the same. Any ideas?
   / Early 70's 310 3 cyl diesel runs for 10-20 seconds and dies. #2
Typical symptoms for clogged check valve(key 9) caused by deteriorating fiber drive ring in inj pump. Loosen the 2 screws(key 13) that hold timing window. With fuel leaking out attempt to start engine. If engine operates correctly clogged valve is the problem. TEMPORARY FIX is clean check ball in valve BUT continuous engine operation without having drive ring replaced could cause premature wear to pump housing requiring NEW IP.
   / Early 70's 310 3 cyl diesel runs for 10-20 seconds and dies. #3
This happened to me when I first got my 2130. Tried near everything then put a new fuel filter on and problem solved. I did have issues with algae in my tank though and cleaned it out before installing the new filter. Funnily I could not see a blockage in the glass filter, but it was there.
(INOP) KUBOTA B7510 TRACTOR (A51247)
(INOP) KUBOTA...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
UNUSED CFG INDUSTRIAL M-DRG MINI DIGGER (A51248)
UNUSED CFG...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
2004 Mack CV713 Granite Fuel and Lube Truck (A51692)
2004 Mack CV713...
2014 CATERPILLAR 279D SKID STEER (A51246)
2014 CATERPILLAR...
