Buying Advice Early '60's MF 35 Utility
   / Early '60's MF 35 Utility #121
The guy I bought my 135 diesel from for $2000 gave the AGCOPUBS shop, and parts manual with the tractor. They are better than any other manual out there,
That's great news, because I have high hopes! I just received shipping confirmation from AGCO. I'm getting excited!
AGCOpubs manuals came in, they're MUCH better. I just have to grab a few 3-ring binders for them. All work on the tractor has been on hold, as I've been working late very day for the past few weeks, and my weekends are consumed by fixing my cars before winter really sets in. One of them almost done, starting the next one this coming weekend, then it's back to working on the tractor.
   / Early '60's MF 35 Utility #124
:thumbsup:
   / Early '60's MF 35 Utility #125
Hi, I've just finished reading the whole thread. You chose well, additionally, what an absolute bargain!
Any progress on the repairs?
BTW, your machine appears quite similar to one of mine - an MF40, appears a little later, but with a 3cyl diesel, has power steering, 3x2 manual gearbox, but no shuttle shift. I still don't know what year it is, est 1966?
Does yours have hub reduction and inboard double-disc brakes in the axle housing, or no reduction and outboard drum brakes?
As far as the absence of a diff lock - use your "steering (independent) brakes" carefully if you start to lose grip on one wheel, brake that wheel a little. Our MF135 has a diff lock but it never gets used - gets stuck unless there is absolutely no load between axles it refuses to release.
Thanks, I think so too! Repair progress is in my other thread, which you've already replied to:
http://www.tractorbynet.com/forums/...353411-repairing-mf35-utility-hydraulics.html
I was hoping for a Perkins diesel, but as you said (and others in this thread) I got a pretty good deal on this machine so I couldn't pass it up! Mine has no reduction and outboard drum brakes. Kenneth suggested the same thing as far as walking the tractor out of a tough spot using the brakes. At first I was planning to find a housing that has a diff lock, but decided I'll just roll with this machine as-is. Check out my other thread for continued progress, I've now got the hydraulic pump out and apart on the work bench.
   / Early '60's MF 35 Utility #127
PatrickS2222 there are 3 likely reasons your diff lock sticks on.1) it is torque locked.Turn the steering wheel 1/2 a turn left then the same to the right ,this usually breaks the torque lock effect and allows the diff lock to disengage.
2) The diff lock pedal has seized from lack of use.Where the shaft comes out of the housing soak it with nutcracker or wd40 or some other penetrating oil. Be patient. Also expect to use a pry bar to disengage the pedal as you work movement back onto the diff lock pedal. Alternative is to use a mechanic (expensive option)
3)make sure there is a return spring on the diff lock pedal to disengage it. Sometimes a spring will break.
   / Early '60's MF 35 Utility #128
Ha Ha ..... Shaeff, I was just reading the other thread! :laughing: I was going to ask you if it's the same tractor. :eek:
While we all see some "shortcomings" in the machine we have, regardless of what it is, we should instead keep in mind what it will do for us. For instance, our loader is wide-tracked, heavy and very stable. I love the bucket capacity it has, but a 4-way bucket would at times be a huge bonus. The additional torque a 4cyl Perkins would be at times welcome, as would 4WD, but these features wouldn't by me be frequently used, and they all come at a price.
I consider myself reasonably lucky obtaining a reasonably capable machine for AU$2500, whilst realising it needed repairs, it's pretty-much a personal opinion whether to describe it as work or hobby - I tend to view it as hobby. If you are of the same view, I reckon, like me, you'll enjoy driving yours after it's back together and working. I had to overhaul my engine, repair a damaged bucket, one brake was oil-soaked, I promptly blew a hose ..... it's quite a list! That said, now she's a rather capable machine considering her age, and extremely useful for everything from carrying winter's firewood to shifting the vege garden soil and compost around (cuts down the shovel-and-wheelbarrow work notably :D).
Our MF135 was my father's tractor - it's up to us to look after it. It is used generally for slashing, crane attachment lifting, pulling things about - it's lighter and more manoeuverable. All our children, and yes, both our daughters can very capably drive it. My neighbours love it too!
I shall start a thread as soon as time permits to give you all their stories.
I place a much higher priority on function and reliability than appearance, so they both are always wearing their "working clothes". I do agree though it is preferable to see them looking tidy, rather than rough.
Thanks for your tips Redman :thumbsup: You are correct in that it is indeed difficult to neutralise torque-lock, and also its pedal shaft seizes very quickly - to the point where we tied the pedal permanently in the released position. I find judicious use of steering brakes the best remedy, the same action as I used to employ on our old MF35 when I was growing up. ;)
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
40' CONTAINER (A54757)
UNUSED XSTAR 250 GALLON FUEL TANK (A54756)
UNUSED XSTAR 250...
2013 Ford Edge (A54815)
2013 Ford Edge...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
49" X 79" EXPANDED METAL RAMP GATE (A54756)
49" X 79" EXPANDED...
