E85 Question
   / E85 Question #1
lonesome
Bronze Member
SW Iowa
International Diesel B414/Case 85XT Skid Loader/2k F250 SuperDuty 7.3 PowerStroke/John Deere 'B'/Allis Chalmers WD45
Anyone tried running E85 in their multi-fuel tractor(s)? Any problems, do you run it as the main fuel or start on regular gas then switch over? Just curious as I see the E85 is about 40 cents a gallon cheaper. Thanks Steve
   / E85 Question #2
Traditionally a multi-fuel tractors like Older IHs and JDs would start on a high qaulity fuel than once warm were switched to a lower qaulity, heavier fuel, like kerosene. Now E85 will burn just like regular gas it just takes more E85 to get the work done. The only problem i would see with using it is it is very corrosive and pratically destroys rubber. So yeah it would run E85 but you would probably end up with a damaged fuel system.
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51691)
2016 Ford F-550...
METAL FILING CABINET (A53843)
METAL FILING...
2025 CFG Industrial 680 (A50123)
2025 CFG...
