E bike recommendations?
/ E bike recommendations? #21
Trek makes a good bike. Unfortunately, not all are built that well.
/ E bike recommendations? #22
Yep, great bikes that you will enjoy. Ride safe!
/ E bike recommendations? #23
Fenders are great when riding in the rain. Even hard core racers use them on wet training rides.
Enjoy the new bikes!
/ E bike recommendations? #24
We just got back from a ride and my backside is hurting, we made need some kind of upgrade in the seat department.
/ E bike recommendations? #26
Seats are tricky, finding one that you like is a very personal thing and proper adjustment is vital. Play around with the forward/back position, tilt, etc and see if that helps. If it doesnt, start looking as there are about 1000 different seats out there - one for every bum as they say....
/ E bike recommendations? #27
I solved that problem with this suspension seat post:
It isn't cheap but I figure my butt was worth it.
You need at least 3.75" of clearance between the seat rails and the top of the seat tube for a good fit. It's only available in 27.2 MM so depending on the diameter of your existing seat post, you may also need a shim.
I have a suspension seat post, it came on the bike, but it might not be the best.
/ E bike recommendations? #29
I plan to add a suspension seat post to my ebike.
/ E bike recommendations? #30
When I bought my bike they sat me down on a small piece of sponge rubber. When I stood up there was two indentations where the base of the pelvis had been. They rolled two small ball bearings into those indentations and measured the distance between them. The tape measure was applied to the range of seats they had in the shop. Where the distance fitted best, that was the seat I bought. The seat is a hard one and the only time I notice it is after about two-n-a-hours of quick trail riding.
/ E bike recommendations? #31
My wife and I both have recumbent trikes. I have knee, back and shoulder issue's so riding an upright just isn't going to happen. I've been thinking about adding an electric system to the trikes to aid in hill climes. 20210212_164209.jpg20210210_160127.jpg20210210_135658.jpg
I think but don’t quote me on this, they make systems you can add. The two drive systems if you are looking at a regular bike is mid drive (the motor is down by the pedal cranks, and rear hub drive. I think they make kits to add the motor to the rear hub being the easiest.
we have about 130 miles on them so far. Really enjoy being able to ride further. I rode it into town a few days ago, about 6 miles, to help a friend with something. I texted him and said I was riding my bike in, I’d be a half hour. He jokingly texted me back and said make it 20 minutes. I turned the assist all the way up and probably averaged about 18 mph.
My friend took it for a test ride, I thought he’d be gone a minute, he was gone longer than I expected. He came back smiling and said “Dave that’s cheating”.
/ E bike recommendations? #34
Often too much padding on the seat makes it less comfortable. You want to put weight on the "sit bones" that the shop measured for you. When there's too much padding the sit bones sink in and you put pressure on other parts. That can include nerves that go to a significant part of the male anatomy. If that part's going numb then a firmer saddle can help.
Some guys tilt the saddle down to reduce numbness. That's a bad idea as you're then constantly sliding down and having to push back up. I start with the saddle level and change the angle in very small increments to account for the saddle's shape.
/ E bike recommendations? #35
Tip: A lot of bikers use a product called Rock_n_Roll for chain cleaning and lubrication. It's a small bottle of light blue 'oil' and a white waxy substance which settles in the bottom of the bottle. Get the bikeshop to put in a small ballbearing when you buy it. It breaks up the waxy substance very quickly. Much like a paint 'rattle can'
I went back to the bike shop to exchange a lock that didn’t work and while there bought a bottle of a wax lube you describe. My backside is adjusting to the bike seat, plus I’m wearing padded bike shorts which help.
/ E bike recommendations? #37
The above info also applies to the women out there. We been riding for 40 years, and the seat height, tilt, for/aft position is very important. And one setting may not fit someone else riding your bike. Enjoy your ebike. Jon
/ E bike recommendations? #38
Just saw this on Facebook - you dont need a $200 Ebike when you can get this baby that does "50-60 mph" (with what looks like no front brakes) for a mere $200.
Good lord, someone is going to die on that thing.
An update. We are in the middle of a stay in Moab Utah. We brought the bikes with us. I’ve got about 550 miles on mine. They have a couple of nice trails here. Unfortunately I came down with COVID and that put the kibosh to the bike riding and hiking for a while. I’m vaccinated and it’s about like having a bad cold or a normal case of the flu. A couple pics of the bike paths.
/ E bike recommendations? #40
Awesome photos and hope you are feeling better soon!
