Dynamo wiring for a Kubota B7100D
   / Dynamo wiring for a Kubota B7100D #1
gshields
B7100D
Hi, I'm a brand new member and haven't learned all the forum functions. My question is that my dynamo on my Kubota B7100D wore out and has metal chips in it. I bought a replacement one, but now that i have the old one off i have noticed that they are different. Everything is exactly the same the shape and mounting, but this new one has 3 wires (yellow, white, and brown) and my old one has just 2 wires (both gray). Now, I'm in a dilemma, i don't know which wires to hook where. Any assistance would be greatly appreciated. Thanks
   / Dynamo wiring for a Kubota B7100D #2
I know polarity does not matter withe dynamo connection but my replacement also had two grey wires.
   / Dynamo wiring for a Kubota B7100D #3
I have a B7100 service manual as well as an owners manual for B7100 HST, each with wiring diagrams. I can email them to you if you think that would help.
Thanks, but i have the wiring diagram, it shows 2 gray wires just like the old dynamo that i removed, however the replacement one has 3 wires. I've since have been able to disassemble the old one, it looks like if i can find the 2 bearings somewhere, i should be able to just replace those and still use the old one. Just keep the new one for the next time. thanks all
   / Dynamo wiring for a Kubota B7100D #5
I think one of those wires is a center tap or a common for two windings. If I remember correctly each leg was fed into half a full wave bridge rectifier and that way you could get doiuble the charge rate. Try mounting and see what the voltage between the three. You should see I combination with a higher one and the voltage between either of those two and the third should be lower.
On a lot of small equipment with magnetos and such one winding charges the battery and the other is just ac to run lights or an electric clutch.
David Kb7uns
Case CX210D Excavator (A50514)
Case CX210D...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2004 Ford F250 (A50515)
2004 Ford F250...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
8ft Fork Extensions (A50322)
8ft Fork...
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
