DynaBrade-DynaFile II
   / DynaBrade-DynaFile II #1
Scotty370
Platinum Member
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
In the intrest of 'full-disclosure', I worked for these folks some 40 years ago! In fact, I drew the drawings for the patent office when this was a 'basement', fledgling company(?). They're now a multi-million dollar industrial tool manufacture.
I have absolutely no vested intrest in them! (Unfortunately) :(
OK, That's out of the way! About the only thing I did manage to end up with is a Dyna-File II. I don't know how I live without it. Today, I burned holes that needed to be 1" dia in 1/4" plate. Got close, and then finished them up with the DF-II. The only reason I bring this up, is I use it daily, when fabricating, and being and industrial tool, folks may not know such a tool exists! . Pricey? Yep! But I've seen them on E-Bay, etc. Do some Googling. Here's one link to wet your apetite. ~Scotty
PS- I just looked a e-bay myself for belts. Note these come in air&electric
Dynabrade Dynafile II
   / DynaBrade-DynaFile II #2
How is this air sander going to make the hole any larger?
Would it not be simpler to drill out in larger sizes till a 1 inch bit with a half inch shank can be used. Or get it close then use a die grinder, far less expensive than that air sander.
Perhaps I didn't explain myself properly. This is a belt grinder that's configured to get into spots that other types of tool just can't get into. In the hole example, you stick the nose of the tool into a hole as small as 1/2" and grind the edge as desired. Your idea certainly works, just thought I'd identify a tool that I love, to folk that don't even know such thing exist. ~S
How is this air sander going to make the hole any larger? This is not a "sander"! It will remove mild steel stock, nearly as quick as an angle grinder.
   / DynaBrade-DynaFile II #4
The guys in the machine shop at work have a couple of them. Very handy; so I bought a $40 imitation fr Horrible Fright a couple of years back. It's nowhere's near as beefy or powerful. But as you say, sometimes it's the only thing that fits.
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
Landscape Wagon (A50860)
Landscape Wagon...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2008 Utility Trailer VS2RA 53ft T/A Reefer Trailer (A48081)
2008 Utility...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
