Dying alternator?
/ Dying alternator? #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
My alternator - 1 wire Delco- charges intermittently. 3 seconds on 7 seconds off there is no corelation between rpms and the voltage. The wire connection is clean and solid.
Do you think the alternator is going south? I would expect more like sudden death and not this agony. Experience, anybody?
/ Dying alternator? #3
If this is on a tractor of high hours I would suspect the brushes are worn / failing or sticking.
There should be a brush/ regulator rebuild kit the bolts on.
I have done this on other brands of alts.
When/ if you have it apart the front bearing is a 6203 2 RS.
Craig Clayton
/ Dying alternator? #4
I had a alternator that would work intermittently on my '96 Dodge-Cummins with 350k miles. When it quit working, there would be a buzzing in the radio telling me that the brushes were probably arcing due to poor contact. I replaced it with a rebuilt and the problems went away. However, I don't think it is a 1-wire alternator.
/ Dying alternator? #5
Might be Brushes bad,,,,Brush set is simple, especially if you buy them in brushholder. they are held in place by tooth pick and it is removed after you put it together..other than that the regulator is no-repairable.Replace the whole thing, but there are several charge rates for different amps. Look at bridge rectifyer to see any charred spots on diodes. Last but not least there is a diode trio,,,Never cross the leads when jumping, ie reverse polarity, this alternator is non-forgiving to such events.
/ Dying alternator?
We had a lot of rain and it started to charge. I think it is the output stud. It turns freely and it shouldnt.
As of now i keep it on battery floater every so often and will dig into it on the weekend.
/ Dying alternator?
I split the alternator, tightened the nut on the end of the output stud and it works like new. In case you ever face similar situation, it is 30 minutes job. Hardest part was to get the alternator out and pur it back in.
Fimco 45 Gal Sprayer (A64119)
Fimco 45 Gal...
2012 VOLVO SD105DX SMOOTH DRUM ROLLER (A64279)
2012 VOLVO SD105DX...
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
YELLER FLAT FOLD ROW MARKERS (A63291)
YELLER FLAT FOLD...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
