DX55 Tilt steering won't stay tilted
   / DX55 Tilt steering won't stay tilted #1
agford4x4
Hempstead, TX
Case DX55
My tilt steering seems to have loosened up over night. The steering wheel is now straight up and down. The lever seems to move OK, but the steering wheel will not lock or stay in the tilted position. Does it need a shot of oil or adjustment? Ideas?
   / DX55 Tilt steering won't stay tilted #2
Read this thread in the New Holland forums. The tractor is not exactly the same as yours, but the problem is similar. In that thread the steering column will not tilt. Your problem is the tiny pin that operates the shock is stuck in the down position, and it won't loosen by itself. You have to work it loose and get it freed up. When it is stuck down, the lever does nothing. Don't be surprised if you cannot get the pin unstuck and have to replace the shock.
AWESOME! Not the pin being stuck, but the info.
thanks!
Im hoping that since I caught it literally overnight, its unstickable, but we will see. There was an awful lot of debris in there.
   / DX55 Tilt steering won't stay tilted #4
got it freed up!
Thanks all!
JOHN DEERE Q 850 M LOT NUMBER 226 (A53084)
JOHN DEERE Q 850 M...
2121 (A51244)
2121 (A51244)
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
