DX55 Owners...Can you check your manual for me?
   / DX55 Owners...Can you check your manual for me? #1
agford4x4
Hempstead, TX
Case DX55
Since i have some obvious typos in mine, i would like to know what the adjustments are on the inching pedal cable adjustment (section 3-30, 3-31) and the Clutch pedal adjustment (section 3.32)
For inching pedal cable adjustment i have
2.95" to take slack out of cable
and .20" for total cable travel
For CLutch pedal adjustment i have:
Free travel should be 3/4-1-3/16"
Also, WTH is the difference between inching pedal and clutch?
   / DX55 Owners...Can you check your manual for me? #2
I scanned the Inching Pedal adjustment page from my manual. It is the 2007 manual for DX55 and DX60.
The Clutch adjustments in my manual are the same as you listed. They do not apply to the EHSS models, but they are for the regular gear shift SSS models.
  • Inching Pedal.pdf
Thank you very much....
I never got the terminology down correctly. Do i have a clutch or an inching pedal? My DX55 has 4 gears on the right, forward/reverse on teh left that require use of the clutch, and then L/M/H on the side of the seat.
I think that means i have an SSS, so does that mean the inching pedal adjustment does not apply to me?
   / DX55 Owners...Can you check your manual for me? #4
Mine is EHSS and is exactly as you described, EXCEPT: no clutching is needed to go from forward to reverse. The inching pedal takes the place of the clutch (similar funtion - different name) for inching in to attach equipment etc, but otherwise it isn't needed to start/stop/reverse. If yours is a SSS, you will see a rod linked below the clutch, forward to the left side of the tractor. The EHSS has a small cable that runs from the lower clutch pedal up under the left side panel of the steering column.
OK, yeah, i have to clutch to go from forward to reverse.
THREE POINT WYLIE SPRAYER (A58214)
THREE POINT WYLIE...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
