Dx 45 starter clicks.
   / Dx 45 starter clicks. #1
compact freak
dx 40 case ih
Have a dx 45 with 6000 hours on it. Installed new starter but starter still clicks. Can jump starter and starts every time. Sometimes it will stop clicking or will start. Seems to be worse when engine has been running.
   / Dx 45 starter clicks. #2
have you checked the battery and/or battery cables?
Just cleaned both and seems to work. Not sure if that was the problem.
   / Dx 45 starter clicks. #4
Probably it was the issue and possibly you didn't need a new starter at all.
Diagnostically, you seem to have started at the wrong end of the trail.
:wrench:
   / Dx 45 starter clicks. #5
I always suspect the ignition switch, that is where I would have started.
Going to try switch still acting up. Thanks to all.
Not the key switch!! Would never be that easy!! Anymore ideas?
   / Dx 45 starter clicks. #8
How many volts is the battery putting out, clean and tighten the cables. Have you checked the ground where it connects to the chassis.
12.9 at cable at the starter. 11.6 at little wire at starter. Cables are tight at battery
   / Dx 45 starter clicks. #10
The starter solenoid is worn out.
2007 MACK CV713 ROLL OFF TRUCK (A58017)
2007 MACK CV713...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
